Transmission troubles
I posted awhile back with some weird transmission issues in my fiance's 2004 1500 3.7L.
Finally threw a CEL and pulled the codes:
P0700
P0731- Gear ratio error in first
P1790- Fault immediately after shift
P0944- Loss of prime
P0876- Under drive pressure switch sense circuit
The issues she has been describing to me:
It hesitates to go in gear (sometimes)
It hesitates to shift out of first and maybe second (sometimes)
It "chokes down" at a stop (rarely)
and of course when i drive it, none of this happens so i can only take what she tells me and try to fix it.
Just 2 weeks ago i changed the fluid and both filters and added lucas stop slip. seemed to help for maybe a week.
The fluid looked and smelled good, and still does.
Can some one help me out with this?
P0700
check the trans fluid level I know for my 08 the transmission is sensitive to the amount of fluid in it 3% out either way and it has issues, but there is also a sensor on the rear diff that is in a housing that can collect moisture and corrode (that was its main issue)
has it thrown a P0900 by chance?
Do, go on with idiotic statements. I'll flip my tow mirrors any which way I want, whether I'm towing or not.
