Truck won't move
Old 08-17-2013 | 10:42 AM
66three83's Avatar
66three83
There are many threads on this subject. I believe it is a faulty valve. Where it's located I don't know. I never worried about it after I found out it does no damage. My truck has 155k miles, it's had that symptom since about 50k, and trans still works great.
Old 08-17-2013 | 11:14 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
When was the last time you changed the transmission fluid and filters?
Old 08-21-2013 | 01:04 PM
bggdgg's Avatar
bggdgg
Default trans fluid
Rebuilt transmission about 25,000 miles ago.
Old 08-21-2013 | 02:01 PM
Izero's Avatar
Izero
This kind of information should always be posted in your original post, as it helps a lot.
I bet that there is an issue with the rebuild, you should bring it back to that shop and see what they will do to set it right for you.
Old 08-22-2013 | 03:37 AM
GabrielNestor's Avatar
GabrielNestor
Originally Posted by 66three83
The computer doesn't do it's thing until the truck warms up? That's a crock. What bggdgg is experiencing is torque converter drain down. It causes no damage, you just have to wait a few seconds for the pump to fill it back up after start up. Takes maybe 10 seconds after starting. That may or may not be the OPs problem. It sounds like his trans won't engage at all.
Exactly my transmission doesn't engage at all in any gear finally got around to diagnosing the problem when discovered that I need a torque converter repair sleeve and hopefully that'll solve the problem
Quick Reply: Truck won't move
