Cv axil assembly
Old Mar 26, 2014 | 08:47 PM
Darkerr's Avatar
Darkerr
Default Cv axil assembly
I'm trying to change cv axil got old one out when puting new one in I put spindle end in first it will not retract enough I need about an eighth of an inch how can I get it what am I doing wrong. I should mention it should go with out saying but it is the transfer case end I can't get on should I switch ends do I need to remove tierod and pop a ball joint any help is appreciated I have been trying for two days some one please help
Last edited by Darkerr; Mar 26, 2014 at 08:54 PM. Reason: Did not wright enough info
Old Mar 26, 2014 | 08:58 PM
lxman1's Avatar
lxman1
Site Moderator
What might you be working on? That info is kinda important.
Old Mar 26, 2014 | 09:08 PM
Darkerr's Avatar
Darkerr
I guess that might help 2008ram 4x4
Old Mar 26, 2014 | 10:23 PM
Post up in the 3rd gen ram section. They will have answer for you there.
Welcome to DF!
Old Mar 29, 2014 | 11:19 AM
jrferg77's Avatar
jrferg77
You should be able to just pop the upper ball joint and that will give you enough room
