Shift solenoid testing
Old 08-22-2015, 04:45 PM
goatman's Avatar
goatman
goatman is offline
Default Shift solenoid testing
Can anyone help with with the testing procedure for the solenoid pack out of the vehicle. P0700 stuck in limp mode fluid is pristine. The trans does not slip and is stuck in 2004 5.7 . I have no prev knowledge of the trans operation had a blown eng and I just finished installing new one .
Old 08-26-2015, 11:02 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
1) download a free copy of the service manual that is linked in my signature below and go through it to see if there is something that will help. I would ask you need a StarScan tool but I might be wrong.
2) take the truck to a shop that specializes in transmission work and let them do a full and free diagnostics. Most trans shops will do this at no charge.
Overview, almost every P0700 code I have seen needed a full rebuild or replacement. Hope you got that truck really cheap.
The following 2 users liked this post by weedahoe:
Bill Van Vliet (06-24-2019), Ramblk43 (02-09-2021)
Old 08-26-2015, 05:50 PM
goatman's Avatar
goatman
goatman is offline
Thanks for the link The trans will shift normal I put a new solenoid pack in it that was supposed to be rebuilt it worked fine for about 3 miles trans tight no slipping then dropped back into limp now it's throwing a 0750 only so I'm going to try another pack that is new see what happens.
Old 10-01-2015, 09:28 PM
goatman's Avatar
goatman
goatman is offline
FYI The new solenoid pack fixed my issues.
Old 10-03-2015, 04:41 AM
abarmby's Avatar
abarmby
abarmby is offline
Thumbs down
Aw great news. I thought for a moment, this was going to turn out to be a "throw parts n' money at it" thread until the issue was fixed.
Good skills
Al.
Old 10-03-2015, 06:20 AM
goatman's Avatar
goatman
goatman is offline
Post
Good skills
Al.
Back atcha!
Old 10-04-2015, 01:16 PM
stenerson's Avatar
stenerson
stenerson is offline
Yep, changing the solenoid pack 3 years ago fix the problem fo me.
Old 05-29-2018, 06:56 PM
SuzAllen's Avatar
SuzAllen
SuzAllen is offline
Default Service manual link
Back atcha!
Where can I download the service manual
Thank you
P0700 and 0740 and need to pass smog
Quick Reply: Shift solenoid testing
