LSD Clips wore into cap/Housing and True trac and Auburn ?
Old Oct 17, 2015 | 07:17 PM
Joe.G's Avatar
Joe.G
I got the rear back together, Everything is set where it is supposed to be, So far so good There seems to be a little bit more play back and forth then before if I have it jacked up and and rotate wheel one direction then change direction also may have a slight clunking sound which you only hear if truck is on lift/jacked up, I believe this to be the Tru Trac unit. I have not tried it out yet in any type of off road/low traction situation. I will change the fluid in a few hundred miles and put on a aftermarket cover at that time also.
Old Apr 27, 2019 | 01:00 PM
car5car's Avatar
car5car
I posted thread in 98 Durango section today, describing the problem in details.
Old Jul 14, 2020 | 03:41 PM
nedhlp7's Avatar
nedhlp7
Default lsd clutch pack retainer clip
my passenger cap is worn down a bit too, trying to see how bad yours were but the link to your photos does not work
Old Dec 14, 2021 | 10:49 AM
Joe.G's Avatar
Joe.G
Just wanted to give an Update, the Rear is holding together just fine, I am going to be adding a TrueTrac to my 14 Camaro 2SS/RS along with 3.91 Gears. I am running Torco Fluid in the Ram but would like to run a 75/90 Synthetic in the Camaro and I am leaning towards the Redline NS since it is the only one I can find with out LSD additive in it.
Old Dec 14, 2021 | 10:54 AM
The friction modifier doesn't hurt anything being in there.
Old Jan 3, 2022 | 12:29 AM
vietti2's Avatar
vietti2
True track for sure.. auburn will loose its posi around 30 thousand.. then only work as a peg leg
