transmission fluid
Old Dec 14, 2015 | 03:27 PM
pritch2007's Avatar
pritch2007
Default transmission fluid
What transmission fluid you use/recommend on a 2007 ram 1500 5.7L V8 Hemi? I've got 71000 on it and have never changed it
Old Dec 14, 2015 | 03:35 PM
Manufacturer recommended.
Old Dec 14, 2015 | 04:27 PM
p38251's Avatar
p38251
Owners manual will tell you
Old Dec 14, 2015 | 07:16 PM
pritch2007's Avatar
pritch2007
Thanks, you usually change it about 75000?
Old Dec 14, 2015 | 07:50 PM
JSMCO's Avatar
JSMCO
Old Dec 15, 2015 | 10:20 AM
p38251's Avatar
p38251
I 2004 it was every 30k. You should really check your manual for requirements on preventive maintenance.
Old Dec 15, 2015 | 10:10 PM
MikeHTally's Avatar
MikeHTally
60K is the interval. Any brand-name ATF+4 will do. Even Wally-World's Super Tech is pretty good stuff. Change both filters, making sure you get the right flat filter (4x2 vs. 4x4). My drop 'n' drain used seven quarts.
Old Dec 15, 2015 | 10:30 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I use the Royal Purple ATF-Max. Last time I changed all 17qrts out with my filters. I've got around 50 qrts of RP engine oil out in the shop. I caught it on sale at $2. I remember paying $8 a bottle for the ATF-Max. The differential oil I've never been able to catch on sale but thankfully you only need 3 qrts ($20ish a bottle)
Old Dec 16, 2015 | 12:13 AM
pritch2007's Avatar
pritch2007
Thanks for the info MikeHTally and weedahoe!
Old Dec 16, 2015 | 09:36 AM
HemiLonestar's Avatar
HemiLonestar
As long as it is ATF+4 or equivalent
