Passenger window switch not working
Old Oct 12, 2025 | 11:15 AM
  #21
savannah996's Avatar
savannah996
Originally Posted by Fxguy72
Try the yellow wire to the window with a reliable ground. If the window goes up and or down then the wire is fine. Then it is a problem further down the line. Pick up a Hanes manual or the window wiring diagram. Go old school and manually trace the wiring backwards. Constantly check the window at each junction. It is a pain in the butt but it will lead you to the problem. Also check each union for corrosion. Sometimes the unions get funky and have to either be replaced or cleaned with a wire brush. After you clean them apply dielectric grease to both sides. Hope this helps?
I already checked the yellow wire it's not getting power for the passenger window switch.
Old Oct 12, 2025 | 11:17 AM
  #22
savannah996
Yep, goes back to the drivers side switch, Connector 2, pin 8. Technically, its the 'window module', but, I believe that the drivers window switch is attached to it.....
That was one of the first things I did was check the driver side switch for the yellow wire for the passenger switch but it does not come from anywhere in the driver side window switch assembly
Old Oct 12, 2025 | 11:19 AM
  #23
savannah996
The cause of my problem is no power at the passenger side window switch via the heavy gauge yellow wire. I pulled apart the connector at the door jamb and verified there's no power coming into the door from the jam. I probably just run a new wire from the circuit breaker to the door.
Old Oct 12, 2025 | 11:52 AM
  #24
Fxguy72's Avatar
Fxguy72
Get a wiring diagram for your window and find out what the yellow wire is for. You might bypass another feature on your truck that is connected to your window wiring. Best to know what that wire is for? Wire chasing... I know how to do it and I hate doing it. Valuable skill but a headache.
Old Oct 12, 2025 | 12:08 PM
  #25
is there a separate window module in the drivers door?
Old Oct 12, 2025 | 12:13 PM
  #26
Whitetrash04derdge's Avatar
Whitetrash04derdge
Originally Posted by Joshh8120
I've got an 04 ram 4 door and the passenger switch randomly stopped working. I tried wiggling the wires like some suggested and got nothing. I read where some also said it could be a bad master switch so I replaced the switch and still nothing. I can roll every window up/down on the master switch and the rear window switches both work fine. It's only the passenger side switch that won't work. The door lock button works, but the window switch doesn't work and is not lit up. Any ideas?
Hey buddy not sure if you fixed this yet but it's 100 percent the master switch. If you had a broken wire or if even the other switch was unplugged the window wouldn't operate at all some how it messes with the system. Go to your local Autoparts store and buy one and try it in the parking lot I've seen this a dozen times
Old Oct 12, 2025 | 01:03 PM
  #27
savannah996
Sorry I just realized I hijacked the thread. But I was hoping the OP had the same problem as me. I bet when i spend some more time under the dash I find it was something i did all along. Like cut a wire or something installing an aftermarket amp or the foglights or my ambient under dash lights. Im gonna get under there today. maybe take some pics for entertainment.
Old Oct 12, 2025 | 01:24 PM
  #28
savannah996
Yellow wire with no power supply
2003 reg can 4.7l
2003 reg can 4.7l
Old Oct 12, 2025 | 03:31 PM
  #29
savannah996
Thanks you were right. I discounted the yellow wire coming out of the driver side window switch is being part of the power mirror system. The yellow wire on the driver side goes to the passenger side switch for power. I saw the YouTube video of the commonly occurring loose solder problem for that yellow wires pin. I just heated up the solder and reset it problem solved. I shouldn't have assumed that yellow wire was for the power mirror circuit.
Old Oct 12, 2025 | 04:03 PM
  #30
Hey, it's fixed. That's all the really matters.
