diy single turbo 4.7l magnum
Old Sep 20, 2017 | 12:43 PM
That's about a good start price to get you going.....more after that.
What are you looking to accomplish by installing a turbo?
Old Sep 20, 2017 | 01:29 PM
Zack Ernst's Avatar
Zack Ernst
To make my truck have more get up and go. It has 33inch tires and 3.55 gears, a cold air intake, high flow exhaust, fastman throttlebody, and a sct tuner tuned by hemifever, so if there is any thing i can do to make 50 more hp for less then $1000, please let me know cause I cant afford to do a turbo.
Last edited by jkeaton; Sep 21, 2017 at 03:49 PM. Reason: Punctuation and capitol letters
Old Sep 20, 2017 | 05:19 PM
You would be better off saving another 500 bucks, and re-gearing the truck.
Old Sep 20, 2017 | 08:10 PM
Zack Ernst's Avatar
Zack Ernst
Yeah. I was thinking about regearing to 4.56s gears also or doing the 08 intake manifold coversion from airram but I don't know which one will give me more noticeable power.
Last edited by jkeaton; Sep 21, 2017 at 02:34 PM. Reason: Punctuations.....learn them....
Old Sep 20, 2017 | 11:06 PM
Gears. That will give you what you want. Cheaper than trying to turbo. Much cheaper.
Old Sep 21, 2017 | 10:05 AM
HemiLonestar's Avatar
HemiLonestar
Yeah, holy **** you need to regear that thing even if you were only to go to 3.92's...I'd be amazed if it got out of it's own way with tires that tall and gears that mild. The manifold conversion won't bring much unless you combine it with cams swap (if you could find or afford a set of HO cams or had customs ground).
Old Sep 21, 2017 | 02:13 PM
Zack Ernst's Avatar
Zack Ernst
What gears do you recommend? Nitro or yukons and do I just need the normal kit or the master kit?
Last edited by jkeaton; Sep 21, 2017 at 02:33 PM. Reason: Jesus for the love of god, learn how to use punctuations
Old Sep 21, 2017 | 03:44 PM
Yukons are really good. Probably just the normal kit. If you haven't done it before though, having someone that knows what they are doing is a VERY good idea. Doing it wrong can get REALLY expensive.
Old Sep 21, 2017 | 03:49 PM
Zack Ernst's Avatar
Zack Ernst
so all i need is ring and pinions for the front and rear diff ?
Old Sep 21, 2017 | 04:18 PM
And the install kits. (shims, possibly bearings, pinion nut, crush sleeve?)
