diy single turbo 4.7l magnum
Old Mar 17, 2021 | 11:07 AM
  #61
Joshua Landers's Avatar
Joshua Landers
Originally Posted by Zack Ernst
I'm running 2008 camshafts ,2008 intake manifold comp cam valve springs , mildly ported heads with no intercooler and meth injection also . Truck has been running great on 8lbs with no issues for almost a year and half also for transmission I have hd2 shift kit , sonnax line pressure booster and 5 speed tcm from jeep grand cherokee 4.7l had issues with tranny slipping before this.
yes I got the transgo shift kit, and I’m about to do a full master rebuild including torque converter. Luckily my truck already has the 5-45rfe software so I don’t have to worry about that. I’ll have to check out the line pressure booster. After I get all my other stuff put on I’ll have to start getting the cams and intake together. I might even just rebuild the engine and drop in forged pistons and see how much boost I can put on those. Do you have yours dyno tuned?
just bought the line pressure booster as well.
Old Mar 17, 2021 | 11:09 AM
  #62
Zack Ernst's Avatar
Zack Ernst
Originally Posted by Joshua Landers
yes I got the transgo shift kit, and I’m about to do a full master rebuild including torque converter. I’ll have to check out the line pressure booster. After I get all my other stuff put on I’ll have to start getting the cams and intake together. I might even just rebuild the engine and drop in forged pistons and see how much boost I can put on those. Do you have yours dyno tuned?
Flying ryan performance tuned it I messaged you on instagram I have the sts install guide if you want it
Old Apr 17, 2025 | 11:04 AM
  #63
JunkyardWolf's Avatar
JunkyardWolf
Default Just buy a kit for the bigger motor
I'm looking to turbo my 02 ram 1500 4.7l v8. I am either going to do a rear mount or just flip the manifold if i am able to do that. I only want to run like 5 to 6 lbs of boost and I also dont want to spend more then $1000. What is involved in doing this
As far I know and have learned and what I'm going to testing in the next couple months is that the 5.7 exhaust headers will bolt into a 4.7 since they share the same bolt pattern. So buy a single turbo kit for a 5.7 bolt it in and get a tune. Obviously swapping bigger injectors in and keeping it under 10lbs until you at least until you regap your piston rings. ( While regapping you might as well swap out for forged internals)
Old Apr 17, 2025 | 11:09 AM
  #64
Rather old thread, don'tchathink? In the neighborhood of 8 years..... If he actually did anything with this, I would have expected him to mention that......
Please pay attention to DATES on posts. Bringing up long-dead threads helps no one.
Old Apr 17, 2025 | 11:12 AM
  #65
JunkyardWolf
Yeah I seen the date on the post. I do know how to read. But when you google Dodge 4.7 turbo this is one of the first things that pop up and I have read several years old post so if anyone reads old post like I do I figured it might help. I'm just trying to help
Old Apr 17, 2025 | 12:23 PM
  #66
Google is not always your friend.
Old Apr 20, 2025 | 08:01 PM
  #67
Lawsuit11's Avatar
Lawsuit11
Boosting your 2002 Dodge Ram 1500 4.7L V8 on a budget of $1000 is doable if you're okay with DIY fabrication, used parts, and modest power gains.
I can break down what’s involved and how you can pull this off, especially with a rear-mount or flipped-manifold setup.
Also have used parts of the 2002 Dodge Ram 1500 4.7L V8.
