3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I am replacing the gears in my rear differential and with used for now to get back on the road. Can anyone point me in the directions of the specs for everything?
Much appreciated.
Thanks for double checking. I actually took the carrier from an 03 with 3.55 gears and limited slip and put my 3.92 ring gear on it. even that was an upgrade because my 2005 daytona had an open rear end. Seems like a dumb choice for a 4wd to be an open rear. everything fit perfect though. Torqued it all to spec and it runs smooth as butter.
