New to Forum and need of help!
Old 01-14-2018, 06:47 PM
Performancema's Avatar
Performancema
Performancema is offline
Default New to Forum and need of help!
My 03 Dodge ram 1500 runs fine on idle but when I press the gas fast and hard the engine will stall. It runs good if I press the gas slowly but once I press the gas quickly or hard the engine stalls. Please help!
Old 01-14-2018, 07:02 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,178 Likes on 2,931 Posts
Check engine lite on? How many miles on it? Does it run ok, aside from not liking large throttle changes?
Moving to third gen ram section for ya.
Old 01-14-2018, 07:21 PM
Performancema
No engine light on and no codes.The truck has 157,000 miles on it. The truck Will run fine on idle
Old 01-14-2018, 07:23 PM
HeyYou is offline
Is that Drive-by-wire? (no direct connection from pedal to throttle body?)
Old 01-14-2018, 07:35 PM
Performancema
Not sure, it might be!
Old 01-14-2018, 07:36 PM
HeyYou is offline
That complicates things some. I don't have any documentation on those, nor any experience with them. Others here do though. Patience is the key. Good Luck.
Old 01-14-2018, 07:43 PM
Performancema
Thank you for your help!
Old 01-14-2018, 07:46 PM
Performancema
I was told just now that it is not a drive-by-wire. It is a direct connection from pedal to throttle body
Old 01-14-2018, 08:10 PM
HeyYou is offline
In that case, I would have a long, hard look at the throttle position sensor. It is apparently ignoring you.
Old 01-14-2018, 09:33 PM
Performancema
Thanks
Quick Reply: New to Forum and need of help!
