Won't shift into OD
Old Mar 5, 2018 | 12:02 PM
lorikay714.lh@gmail.com's Avatar
Default Won't shift into OD
My 2005 1/2 ton RAM has a 5.7 Hemi, automatic tranny and about 245K. Amazingly, it still runs great! However, now it won't shift into OD. All other gears are fine. Also, when starting from a complete stop, it engages into gear, but I have to give it a LOT of gas to get it moving. If I start from 2nd gear, it starts moving normally. I also noticed a noise this morning in the driver side front, but doesn't seem to be an engine noise. I just had the fuel pump replaced and in the diagnosis process, we checked and it's not throwing any codes. Any help will be appreciated!
Old Mar 6, 2018 | 12:40 PM
HemiLonestar's Avatar
HemiLonestar
No such thing as a 7.3 hemi
Old Mar 6, 2018 | 03:07 PM
Sorry...very frustrated and in a hurry when I submitted my question. It's a 5.7. Thank you!
Old Mar 6, 2018 | 03:13 PM
Stat with the basics. What is the transmission fluid level and condition? Any maintenance ever done on the transmission?
Old Mar 6, 2018 | 03:40 PM
Yes, fluid is good and I added a quart of Trans-X. I've had the truck for about a year and have not had any issues nor maintenance with the transmission.
Old Mar 6, 2018 | 03:48 PM
With that many miles and unknown maintenance history, it might be time to drop the pan and see whats up.
Old Mar 6, 2018 | 05:11 PM
Maybe so. I've seen some posts here talking about relays and sensors. I was wondering if that's a possibility, before tearing into things.
Old Mar 7, 2018 | 07:21 AM
Check and see if there are any codes. (pending codes won't turn on the CEL.)
