'03 1500 5.7L P-0441 code help
Old May 17, 2018 | 08:28 PM
AeroViper1's Avatar
AeroViper1
Default '03 1500 5.7L P-0441 EVAP code help
I am attacking a P0441 Evap code so I can get my truck inspected. I noticed a broken clip on the "filter" side of the leak detector. I'm going to replace both clips with hose clamps. Could this be that easy? Also, do these other connections need hose clamps or are they correct in the way they look now.
- Chris
Old May 19, 2018 | 05:38 PM
The PCM isn't seeing the correct changes in airflow into the engine when the purge valve is commanded open. Unfortunately, it doesn't tell us if the flow is too high, too low, or simply isn't changing at all...... It might be a bad valve, bad control circuit, or a bad hose.....
Old May 20, 2018 | 10:08 AM
Gone Fishin's Avatar
Gone Fishin
Totally Agree, check the hoses first. If there are any cracks, even small ones, and yes, the missing clamp can cause problems on the system
Old May 20, 2018 | 02:49 PM
AeroViper1's Avatar
AeroViper1
I've gone through the hoses as best I could and found them all to be in good shape. Im going to replace the clamps on the leak detector and clear the code to see if that does it. I have a friend with a smoke machine so I may go ahead and hook that up if we find some time to do that.
My question on that would be where is the best "entry" point to hook the smoke up to?
Old May 20, 2018 | 03:20 PM
Brake booster hose.
Old May 21, 2018 | 05:11 PM
AeroViper1's Avatar
AeroViper1
I've seen posts about people changing the Evap Leak Detector (first picture) to solve it. Is this worth changing out anyway or should I wait until I've ruled out any bad hoses/clamp spots.
Old May 22, 2018 | 08:53 AM
It's best to thoroughly troubleshoot the problem rather than just throwing parts at it, hoping for a fix........
Old May 22, 2018 | 02:11 PM
AeroViper1's Avatar
AeroViper1
I agree, just not used to computers in my truck. I eliminated everything computer except for an ignition module from my jeep back on the day. I'll adapt
