Fuel supply issue
Old Feb 4, 2019 | 01:16 PM
BeerMe!'s Avatar
BeerMe!
Default Fuel supply issue
2005 Ram 1500 4X4 5.7 Hemi
Truck cranks but won't start.
Swapped the fuel pump relay. Nothing.
Checked fuel pump fuse. It's good.
Sprayed starting fluid in the throttle body and truck started and ran for a minute.
Pulled fuel rails and injectors are not spraying fuel.
Does anybody have any suggestions as to what the problem might be?
Old Feb 4, 2019 | 02:04 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Fuel pump..
Old Feb 4, 2019 | 02:58 PM
The thing that pumps fuel.....
Old Feb 4, 2019 | 04:21 PM
MoparFanatic21
The pump that pumps the go juice
Old Feb 4, 2019 | 07:08 PM
66three83's Avatar
66three83
That’s kinda typical to what I see on this forum regularly!!
Old Feb 4, 2019 | 08:25 PM
What? That folks here have a sense of humor? That's one of the things I like best about this place.
Old Feb 4, 2019 | 08:41 PM
66three83's Avatar
66three83
Was referring to the OP’s question! A lot of threads about obvious bad fuel pumps lately, but that one takes the cake!
Old Feb 4, 2019 | 08:45 PM
Problems seem to come in clusters. You won't see a fuel pump problem for a couple months, then, there will be six threads about them in one day. Goes about the same for every other problem under the sun as well.
Old Feb 4, 2019 | 09:33 PM
MoparFanatic21
I'm assuming this person never worked on a vehicle, at least I hope so. Or he/she is hoping it isn't the pump
Old Feb 4, 2019 | 09:46 PM
I would be hoping it wasn't the pump.... Those are a drag.
