Hesitant Start
Old Feb 25, 2019 | 04:56 PM
  #21
GaRamGuy's Avatar
GaRamGuy
I primed the truck three times after having sat for three hours. It struggled to start. Maybe a leaking injector flooding cylinder?? Will look at doing fuel rail test.
Old Feb 25, 2019 | 05:15 PM
  #22
72rtchallenger's Avatar
72rtchallenger
There's an access port on fuel rail to hook in a gauge , I bought a cheap gauge to check the pressure on mine
Old Feb 25, 2019 | 08:01 PM
  #23
GaRamGuy's Avatar
GaRamGuy
If I hook-up the gauge to fuel line. Would I just keep it hooked up after an initial start? I checked the readings on the rail several months ago while truck was running. it was about 55 psi if I remember correctly.
Old Feb 25, 2019 | 08:26 PM
  #24
72rtchallenger
You dont need to start the truck,,just turn the key to on position 5 to 10 sec. and pump will run, after that see if the pressure holds on fuel rail..after turning key off
Old Feb 25, 2019 | 08:50 PM
  #25
GaRamGuy's Avatar
GaRamGuy
Got it. I am going to autozone to rent their fuel gauge at no charge. I will keep you posted. Thanks for help!
Old Feb 26, 2019 | 11:34 AM
  #26
72rtchallenger
Of course a leaky injector can cause you same issues as well ,,with slow start and loss of fuel pressure,,after checking for fuel pressure loss and if so ,I think you can test the injectors to see if you have a bad one ,, Pull your injector rail and with the injectors on. Put your key to on position not starting the truck. Just for the pump to put pressure in it. And see which one leaks. You have to put paper under neath the injectors.
Old Feb 26, 2019 | 12:25 PM
  #27
GaRamGuy's Avatar
GaRamGuy
Will fuel spray all over when ignition is turned on? Or does this just happen when you attempt to start truck? I was thinking along the same lines to pull injector rail and placing cardboard or paper to determine which one was leaking. I did not feel like checking all 16 plugs to see which one(s) was wet.
Old Feb 26, 2019 | 06:18 PM
  #28
72rtchallenger
Well it shouldn't spray , just lift out fuel rail after its under pressure and hold over paper ,,
Old Feb 28, 2019 | 09:01 PM
  #29
GaRamGuy's Avatar
GaRamGuy
The VERDICT...Paper was placed under each injector. Rail was pressurized. Paper (blue shop) towels were bone dry. Reassembled and it started up smoothly. Fuel pump or Throttle Body??
Old Feb 28, 2019 | 09:09 PM
  #30
GaRamGuy's Avatar
GaRamGuy
Also, I inspected injectors for any leaky o-rings before removing them. It was all very dry.
