Need some help
Old Apr 12, 2019 | 03:10 PM
tecj9's Avatar
tecj9
Default Need some help
I have a 2004 Ram 1500 5.7 4x4. I have a vibration when applying the brakes. I Replaced all pads, rotors, and calipers on the front and rear in July 2018. Everything was smooth until about a month ago (March 2019). But now when my brakes are applied at anything over 50 mph I get a wicked vibration. If I am going slow like 35 mph then I can ease on the break and avoid the vibration.
It feels like it was coming form the back. I was thinking warped rear rotors. Took it to a mechanic shop, they said the same thing. So I replaced the rotors with brand new ones, but it didn't change anything. Same exact vibration/wobble, same intensity. To me it feels like it is coming from the rear. The steering wheel does not vibrator or wobble when I apply the brakes. I kind of feel it from the back.
Any ideas on what could cause this?
Old Apr 12, 2019 | 05:00 PM
Jack up the rear, and shake/move/wiggle everything you can get your hands on in the rear driveline. Might be a bearing somewhere, might be a U-joint, might be as simple as loose lug nuts.
Old Apr 12, 2019 | 07:33 PM
72rtchallenger's Avatar
72rtchallenger
I agree , get it up on a lift or stands and check drive-train, U-joints ect , look at pinion on rear end for excessive play ,, and pull in an out up an down on everything like rear axles
Old Apr 16, 2019 | 09:18 AM
Daves69's Avatar
Daves69
Did you replace the E-brakes as well?
Old May 8, 2019 | 10:24 AM
tecj9's Avatar
tecj9
The e brakes were not replaced. I'll have to lift it up and check everything out. I'll give an update.
Old May 8, 2019 | 11:54 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
That much front wiggle pay particular attention to the inner and outer tie rods
Old May 10, 2019 | 12:45 PM
66three83's Avatar
66three83
Did you even read his posts? He clearly stated it was coming from the rear.
Old May 10, 2019 | 12:51 PM
66three83's Avatar
66three83
Also while it’s up, start it and put it in drive to examine the tires. I once had a tire that had a small bulge that was not evident until I could see it rotating at speed. That vibration would only occur on acceleration and braking. Replaced the tire, problem solved. But it was a head scratcher for quite a while!!
Old May 10, 2019 | 11:02 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Just because he thinks it's coming from the rear does not mean it is (especially if he is coming to a forum for help). No need to be a dick about it.
