Front differential question
Old Nov 6, 2019 | 02:32 PM
Tony Sarmiento's Avatar
Tony Sarmiento
Default Front differential question
2002 1500 4.7 4x4
I have replaced front passenger axel seal 2 times and it still leaks. Please look at my picture and tell me what you think. It would seem to me that the shaft should stay centered in the housing not be laying on the bottom. Dodge parts dept says that the only thing that goes in there is the seal.
Should this be resting on the bottom of the housing?
Old Nov 7, 2019 | 07:30 AM
Lets see the part that the axle plugs into.
Old Nov 7, 2019 | 10:15 AM
TrueDogman's Avatar
TrueDogman
Your thinking same as me. Axle will be centred when it splines up with wheel hub and everything is back together.
Old Nov 7, 2019 | 07:44 PM
I AM curious about bearings to hold things in place though. I would like to think they are on the part NOT pictured.
Old Nov 8, 2019 | 09:31 AM
Tony Sarmiento
Default CV axel
Left end slides thru hub. Right end slides over shaft.
No bearings on this CV axel
So the CV axel slides over the end of that shaft. The CV axel is only held onto the Hub with a 36mm nut and it is a flexible not ridgid axel, so when you slide it onto the shaft then the only thing holding all the weight of the CV axel and the shaft is the rubber seal.
Old Nov 8, 2019 | 10:02 AM
Looking at the parts diagram, there IS a bearing in there, but, doesn't really show how FAR in there. I would be tempted to pull the cover, and have a look on the inside.
Old Nov 8, 2019 | 10:39 AM
TrueDogman's Avatar
TrueDogman
Sorry. I was mistaken what we were looking at in your first pic. I agree with hey yous suggestion.
Old Nov 10, 2019 | 05:47 PM
Tony Sarmiento
So dodge says that there is an Intermediate shaft, C clip, Seal, Bushing, and an Oring.
Old Nov 11, 2019 | 08:12 AM
The parts diagram I looked at listed a bearing. Have a look here. Number 5 in the diagram.
Old Nov 11, 2019 | 09:28 AM
Tony Sarmiento
3= seal
4= bushing
6= Oring
There is no #5 on the passenger side.
