Can feel everything the same in my steering whel and brake and gas pedal
With dash being out several times and not doing it yourself its hard to say , ,,Perhaps get up close to pedals and keep a hand up on wheel an tap it and see if you can locate movement of some sort,,try google a diagram and see if there should be some type of bushing between the mounting bolts on column ,,could be easily left off after being removed a few times ,,need to get in floor and get up close an personal an see if you can see or feel movement ,with tapping the wheel ,, and as much as you don't want to go back , it might be in best interest to go back and show them while there sitting in truck what your talking about , make them stand behind the work
One of the things I always do, is look over what is going to be "repaired" by the dealer - then when they return the vehicle - I go find all the fasteners they didn't reinstall. I don't think there was a time that it didn't go back in for more fasteners. Anything to save a couple minutes.
