06 Ram 1500 remote start install
Old 01-13-2020, 08:44 PM
Eddy Duke's Avatar
Eddy Duke
Eddy Duke is offline
Default 06 Ram 1500 remote start install
I decided to install a remote / push button start on my truck. I am having an issue with it not wanting to crank, I can hear the ignition relay chattering like the signal isnt strong enough to engage the coil on the relay. Battery is good, relay is good, I can still crank the truck with the key no problem. Any advice would be appreciated.
Thanks,
Old 01-13-2020, 09:37 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,390 Likes on 3,130 Posts
Check the connections for that particular circuit from the smart box that is supposed to control it.
Old 01-13-2020, 10:06 PM
Eddy Duke's Avatar
Eddy Duke
As far as what? Voltage output while trying to crank it?
Old 01-14-2020, 07:43 AM
HeyYou is offline
Make sure the connections are good. Does the controller send voltage to the relay to trigger it, or provide ground path?
Quick Reply: 06 Ram 1500 remote start install
