3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Finally got it to fire up. I have a dtc p2074. Runs really rough and hard to start. Idle is non-existent have to keep feathering throttle just to keep it running. Checked for vacuum leaks and have none.
That's a map code, make sure the vacuum line to it isn't cracked/broken, that its plugged in good. Might wanna test TPS as well. (the code is whining about MAP/TPS correlation.)
