2003 RAM New TYC Headlight Assemblies, Now Fast Blinker Problem!
Old Feb 28, 2021 | 03:54 PM
seagiant's Avatar
seagiant
Default 2003 RAM New TYC Headlight Assemblies, Now Fast Blinker Problem!
Hi,
Installed new TYC Headlight Assemblies and now have the Lamp Light and Gong going off, also BOTH Blinkers flashing fast!
Wondering if anyone has any ideas on this???
Old Feb 28, 2021 | 05:11 PM
Alex Medeiros's Avatar
Alex Medeiros
Check your fuses. If not then that means something is up with either the bulbs or the connecting wires that go into the headlights.
Old Feb 28, 2021 | 06:23 PM
seagiant's Avatar
seagiant
Hi,
Thanks, seems if a fuse was blown then there would be some lights out?
All the lights work as far as I know...
Trying to help my sister, will look at the truck myself this week.
Just trying to get some idea what might be wrong.
This started with the new headlight assembly install...
Maybe the Mechanic, pooched a headlight socket wire, will check that out!
Old Feb 28, 2021 | 06:37 PM
Did the new headlights have LED's for the turn signals?
Old Feb 28, 2021 | 08:15 PM
seagiant's Avatar
seagiant
Hi,
Thanks, no they are listed Halogen?
Here is what they are!
I ASSUMED the bulbs would be as original???
https://www.rockauto.com/en/moreinfo...413403&jsn=535
Old Feb 28, 2021 | 08:38 PM
Well, that's should work just like stock then...... Are all the bulbs working?
Old Feb 28, 2021 | 08:58 PM
seagiant's Avatar
seagiant
Hi,
Thanks, yes, that is what she says..
I'm going to pull headlight assemblys back off and check for bad wiring...
And going to replace rear turn signal bulbs and stop light bulbs and marker bulbs and check for socket corrosion and bad wires.
Seems 03 RAMS have problems with rear brake lights, from what I read researching this.
I try not to be a parts changer and troubleshoot first, but if I'm going in, might as well put in new bulbs while I'm there, cheap enough!
Old Feb 28, 2021 | 09:07 PM
Yeah, the circuit boards the bulbs plug into are notoriously flaky. Certainly not one of dodges better ideas.....
Old Mar 1, 2021 | 08:15 AM
big guy's Avatar
big guy
I had problems with new TYC on my old 03.... Try using the signal sockets from the old headlight assembly.
Hopefully you still have them?
Old Mar 1, 2021 | 09:17 AM
seagiant's Avatar
seagiant
Hi,
Thanks, no, my sister threw them away....Grrrrr!
Why would the sockets make a difference if they work???
