Starting issue
I have an 07 1500 with the 5.7L. The other day out of the blue it wouldn't start for my wife. I put a new starter on the other day and it has started having the problem again. Sometimes it will turn over just fine and other times it will not. It's like it begins to spin over and then stops. Topside and bottom connections seem fine. I tested battery voltage and CCA and it checked out. I haven't ran all the grounds down yet but its just weird. Any input or info on this or where I need to check for grounding issues will be much appreciated.
I recommend you check the grounds first. There are videos for checking starter grounds that provide excellent explanation.
The basic test is to see how much battery voltage drops when starter is engaged.
You should start with a battery voltage of 12.7 -12.8, 12.6 at minimum.
Read battery voltage with voltmeter while second person engages starter. Check voltage when starter is not turning but key in start position. The higher the voltage the less demand from the starter, the lower the voltage the higher the demand from the starter.
If you are seeing a high voltage, around 12.0v with starter engaged then most likely a wiring or ground problem.
If you see a low voltage, 9.5 or so, then there is resistance to turning that is more likely mechanical.
These voltages are estimates. You need a known good battery to test your starting issue.
Ok i checked voltage with key off and had 12.6 or so and then when the starter was actually engaged and turning engine over and it never dropped below 10. I found this test on YouTube. I don't know much about batteries and voltage but will check what you suggested this evening after work. Thanks
Starter seems to be getting power and sounds like it actually does start to turn engine over and then just stops. No grinding or broken teeth noise. Someone on another place suggested maybe failing TIPM but it only has this one weird symptom. Sometimes it does turn over for a couple of seconds before it fires up. Its honestly like the starter is turning but like the flywheel or flex plate better have missing teeth and it can't turn but it does turn it just not much at all before it stops.
Trending Topics
Think I would be tempted to do a starter draw test..... (needs an ammeter...) See what starter draw is while cranking, if it draw drops off when the engine stops cranking.... (might be able to see something with just a volt meter too....) If the draw remains, but, the engine doesn't turn, try taking off the serpentine belt, and trying again.
