Help. Transmission
Old Dec 29, 2021 | 10:50 PM
Roach's Avatar
Roach
Default Help. Transmission
Original transmission is a 5 wire neutral safety switch, new transmission I'm installing is a 3 wire, how do I convert the wires to make it work?
Old Dec 30, 2021 | 12:00 AM
master tech's Avatar
master tech
Site Moderator & Tech
What year, Engine and transmission if you know?
Old Dec 30, 2021 | 12:05 AM
Roach's Avatar
Roach
2002 5.9l gas and original is a 46re with 5 pin
the transmission I got is either a 46 rh or re with 3 pin
Old Dec 30, 2021 | 12:19 AM
Roach's Avatar
Roach
02 5.9l 4x4 the transmission going in is a 3 wire 46rh or 46re
Old Dec 30, 2021 | 09:45 AM
What year is the trans?
Old Dec 30, 2021 | 10:07 AM
Roach's Avatar
Roach
01 with the 3 pin
Roach's Avatar
Roach
01 with the 3 pin
Old Dec 30, 2021 | 10:46 AM
Going from the older to the newer... requires a fair bit of finesse. You would likely be better off getting the correct trans for your year truck. There is an adapter to go the other way..... but, nothing for what you are up against.
Old Dec 30, 2021 | 10:59 AM
Roach's Avatar
Roach
Okay what about what wires to splice to make it work???? Asking because I'm in a time crunch bc I have to move out of state in 2 weeks
Old Dec 30, 2021 | 12:17 PM
Have a look at this thread.
