No throttle response after 03 to 05 hemi swap
Old Jan 22, 2022 | 07:25 PM
Mblac0373's Avatar
Mblac0373
Default No throttle response after 03 to 05 hemi swap
Hey guy I need some help. I have a 02 ram 4x4 that had a 4.7 in it. I built a 5.7 with a comp cam and had a whole truck we pulled the motor and harnesses out of for the swap. Everything has went good and it fires up but no throttle at all, just idles. I checked all the wires at apps under battery, the throttle body and pcm connections. I’m getting cam sensor code p0340, egr codes, and the downstream o2 codes which I’m gonna tune out. Anyone have an idea what to check next???
Old Jan 23, 2022 | 07:57 AM
jrsick's Avatar
jrsick
The truck starts right up and idles normally, just doesn't respond to pedal input?
You may want to research engine tone ring mismatch.
Old Jan 23, 2022 | 12:10 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Not likely, all pre-VVT hemis use the same 32 tooth tone ring.
Old Jan 23, 2022 | 07:09 PM
Mblac0373's Avatar
Mblac0373
yeah I’m starting to think it’s the computer. Have checked and reckecked all sensors, wire circuits and grounds. Bell crank is acting right from what I know too. It will try and crank and then cut right back off with apps plugged up. If I upplug either the apps or throttle body it will run at 1200 rpm but not throttle control obviously
Old Jan 23, 2022 | 07:43 PM
Have a scanner that cans see what the APPS is telling the PCM? Sounds to me like it either isn't working at all, or the PCM doesn't understand the signal it is getting. Of course, I would expect either condition to set a code, or turn on the red lightning bolt on the dash......
Old Jan 23, 2022 | 07:48 PM
Mblac0373's Avatar
Mblac0373
Default Apps
No codes other than egr and downstream o2, and evap purge. It’s a 02 ram with a 03 harness and hemi. But we upgraded harness and new computer to 05 for tunability
Old Jan 23, 2022 | 08:13 PM
Think I might check part numbers on the sensors for the throttle by wire system, and see if things didn't change.
Old Jan 23, 2022 | 08:15 PM
Mblac0373's Avatar
Mblac0373
Default Apps
All the sensors and everything came from a running truck that I bought for the swap. I took the whole truck apart got w from that truck that way I was sure to have it all and knew it worked. Except the comp of corse which I just bought and had flashed to my vin and skim taken off
Old Jan 24, 2022 | 07:47 AM
Need a scanner then. See what the PCM thinks is going on.
Old Jan 24, 2022 | 07:50 AM
Mblac0373's Avatar
Mblac0373
Default Apps
Ok I’ll see.
All I have is a simple code reader type.any suggestions on a scanner I need to buy
