Non fouler Cat delete
Old Jan 26, 2022 | 10:28 PM
kohustu's Avatar
kohustu
Default Non fouler Cat delete
I've searched. Trying to find info on the non fouler Cat delete. Just wondering at this point if steel wool needs to be stuffed into the book fouler housings to truck the PCM? Or just screw them on... Anybody know of a thread on this non fouler Cat delete? Thanks!
Old Jan 26, 2022 | 10:36 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
That has been around a looooooong time.....Google search would've been quicker.
Old Jan 26, 2022 | 10:41 PM
kohustu's Avatar
kohustu
Thanks, you'd think. I did just find it, on here. No mention of steel wool. I did see something about steel wool, but can't find it again. I guess I'll try without it.
Old Jan 27, 2022 | 08:04 AM
jrsick's Avatar
jrsick
What's your current setup? No cats, cats gutted, cats drilled? Spacers in O2 bungs? O2 sensors in free air?
Was there a problem you are correcting by modifying the cats, or are you changing exhaust for other reasons?
Do you have a OBD tool that can read A/F ratio?
Don't mean to ask endless questions, just trying to understand your situation so we can offer options.
Old Jan 27, 2022 | 01:45 PM
kohustu's Avatar
kohustu
Thanks, I don't mind the questions at all. Glad to talk with someone who knows something! I pulled the cat out and replaced with pipe. Getting p0420 code once in awhile. Drives fine. Pulled the cat because I was having a undiagnosable issue, and was stuck in the bush, grasping at straws... There's a thread "craziest problem ever" on this, just FYI. Turned out to be a sensor splice shorting out at the back of the engine on the tranny harness, maybe due the this past summers heat wave breaking down the wiring loom.
No scanner to read a/f. Stock engine, although it's a propane dual. O2 sensors are stock, don't know if they have spacers. I believe you can say they are in free air. They're installed still, with pipe in place of the cat.
Thanks!
Old Jan 27, 2022 | 02:03 PM
Need two non-foulers, drill one out, all the way thru, thread it onto the O2 sensor, screw the other non-modified non-fouler onto that one, then screw the whole thing into the exhaust. (these go on the post-cat sensor.) Should solve the issue.
Old Jan 29, 2022 | 10:35 PM
kohustu's Avatar
kohustu
Thanks again HeyYou. That's simple.
Old Feb 4, 2022 | 04:00 PM
Zeppelinrocks's Avatar
Zeppelinrocks
If you have not ordered them yet ebay has them that are already drilled out. It was 10 bucks for it and it cleared the cel for me.
