thanks in advance - springs shocks and mess
Old Mar 2, 2022 | 04:14 PM
memine's Avatar
memine
Default thanks in advance - springs shocks and mess
so noise in rear end made me look at shocks - i had bilstein in shed - 5100 and installed - i have no travel left at rest - 1.5" inch travel to body of shock , 3 inches travel from axle to bump stop - so image more noise and damage to a $90 shock.... wtf?
there is little weight in rear of truck - <800lbs no trailer attached are a coupe images - i can not figure this out...
Old Mar 2, 2022 | 09:21 PM
Yeah, using your shocks as bump stops isn't very good for them..... Are they the correct part for your truck??
Old Mar 2, 2022 | 09:44 PM
rtmtrrdr's Avatar
rtmtrrdr
Shocks are way to long. Get the right ones and you’ll be good to go
Old Mar 3, 2022 | 06:54 AM
ol' grouch's Avatar
ol' grouch
I don' think I've ever seen the travel shaft on the bottom before. Not on a later model vehicle for sure. There's not much room for travel on compression there. Are they the right parts? Are they upside down?
Old Mar 3, 2022 | 07:47 AM
jrsick's Avatar
jrsick
Good inputs.
Are you the one that installed the lift, or was it lifted when you bought it? Did the rear end suddenly start making noise, or has it been going on for a long time.
I recommend start with the lift, take a look at the lift spacers, shackles, shocks, and bump spacer to make sure they are all correct for your lift.
Old Mar 3, 2022 | 03:12 PM
memine's Avatar
memine
thanks in advance - i have concluded that the pads under spring are factory - so not lifted - - I swapped out the bilstein with another - viola no issue correct travel et al... in doing this i saw this - - rub on gooseneck plate - i installed this a few years ago so it is not that bad - but my concern is for this to occur means the leaf spring has inverted.... this can not be a good thing - right? thats a lil more than an inch travel vertical
ats
Old Mar 3, 2022 | 03:16 PM
Cornering with heavy loads??
Old Mar 3, 2022 | 03:23 PM
memine's Avatar
memine
wow - yes that could be a possibility - thanks - my concern is now diminished
Old Mar 3, 2022 | 03:24 PM
I would think you would be able to hear/feel that hitting..... I don't see any shiny metal there though, so, it isn't "real" recent.....
Old Mar 3, 2022 | 03:26 PM
memine's Avatar
memine
thumb up emojii - thanks - always good to have a different perspective and have another set of eyes
