Intermittent Multiple Cylinder Misfire
Old May 6, 2022 | 08:19 PM
Prismatic's Avatar
Prismatic
Originally Posted by jrsick
Those are probably the original plugs. You've got some carbon fouling, but that is probably because the gap is about .80.
Fuel additives can cause buildup as well. Run a can of seafoam through a vacuum line to clear out some of the buildup. When I had my heads off I was astounded at the amount of buildup in the cylinders. Gained a solid 4 miles per gallon after that job.
Old May 7, 2022 | 06:14 AM
fj5gtx's Avatar
fj5gtx
No those aren't original, they're platinum plugs. Factory is copper. They could have a bunch of miles on them, or whoever put them in didn't gap them properly - can't make a conclusion there. Misfires would cause a dirty plug too. I'd replace those immediately with new properly gapped champion coppers.
Old May 7, 2022 | 06:23 AM
fj5gtx's Avatar
fj5gtx
Seafoam won't hurt, but it probably won't do much good either. I'd save your money and just run some lucas upper cylinder lubricant in the fuel tank - along with a couple full tanks of super. After you do the plugs and get the new fuel in there, pull the battery to reset the computer. I suspect its already made alot of adjustments due to wrong gap, wrong plug, and the resulting build up. I'd drive it like you stole it for a couple hundred miles, that'll help clean out the combustion chambers. It'll probably run like a new truck by the time you're fueling up the 3rd time.
Old May 8, 2022 | 09:10 AM
Colbymason1's Avatar
Colbymason1
On this last tank before I changed the plugs I put a bottle of Lucas injector cleaner in it. I changed them Friday and then took it for a drive. It ran great, better than it had in a while. Went to go this morning and it started having a multiple cylinder misfire again. I put in the copper champion 570 at the right gap. It’s not throwing any other codes.
Old May 8, 2022 | 10:05 AM
Dodgevity's Avatar
Dodgevity
Was going to say check coil packs, but since it's "multiple," I'd be looking at the crankshaft or camshaft sensor. Replace crankshaft sensor first. Don't go AM with these. Also if oil maintenance hasn't been good, it might be due to timing chain issues.
Old May 8, 2022 | 10:07 AM
Colbymason1
Oil has been kept up very well. It changed every 3-5k miles. That’s probably where I was going next was to the crank sensor. Last crank sensor I had to change on my girlfriends car it was completely out and not intermittent. I’ll still give this a try.
Old May 8, 2022 | 01:28 PM
Colbymason1
Put a crank sensor in and put about 8 miles on it. I have no acceleration problems like before but when I'm stopped it has a real rough idle. If I take it out of drive or reverse the roughness goes away and it runs great. Only when I have a load on it and no movement do I have an issue. I also unplugged and replugged in my coils to see if there was a bad connection somewhere.
Old May 8, 2022 | 02:13 PM
How is your fuel pressure? Lean-burn miss??
Old May 8, 2022 | 02:17 PM
Colbymason1
Pressure is good. I’ve put a gauge to the rail and checked.
Old May 8, 2022 | 02:18 PM
So much for that thought.
What brand crank sensor? These trucks REALLY don't like the aftermarket sensors.....
