Intermittent Multiple Cylinder Misfire
Old May 19, 2022 | 06:02 PM
  #31
Colbymason1's Avatar
Colbymason1
What are your thoughts on a bad cam sensor throwing off ignition timing and then the O2 sensor trying to lean it out for that reason
Old May 20, 2022 | 09:17 AM
  #32
fj5gtx's Avatar
fj5gtx
Originally Posted by Colbymason1
I’ll have to give that a try. Maybe some bad wiring right there causing it to be intermittent… I have checked fuel pressure on the right rail and it was good but I don’t ever get a chance to when it is missing.
Probably multiple problems, just work one problem at a time. Upstream o2 sensor values play a big part on air/fuel mix. Switching o2 sensors side to side allows you to figure out if the sensor is bad or wiring/ecu malfunction. Get that solved and then lets have a look at the obd2 outputs again and see what the computer is doing with good front o2 readings...
Old May 20, 2022 | 09:46 AM
  #33
fj5gtx's Avatar
fj5gtx
Lots of conditions can cause misfire, including a lean air/fuel mixture. Chase the obvious error first, then see what the computer logic does with good o2 sensor readings.
Old May 20, 2022 | 10:12 AM
  #34
Colbymason1
Yeah I’ve got a sensor coming I’ll throw it on today and see how it works.
Old May 20, 2022 | 12:51 PM
  #35
For the front O2 sensors, I like to replace both of them.....
