fuel trim
Old May 10, 2022 | 10:16 PM
dsalak86's Avatar
dsalak86
Default fuel trim
so i have notice that my fuel consumption is getting used up more and more. so i have looked it up on my scanner the short fuel trim is -.8 / long term fuel trim is -23. so i have looked at youtube videos about it and i still dont get it. anything that has to do with fuel i have replaced. any ideas on parts i need to replace? to get my fuel consumption back to normal?
Old May 11, 2022 | 11:06 AM
Those numbers indicate it is pulling fuel..... which should INCREASE your gas mileage. Or, maybe you have a sticking injector.....
Old May 11, 2022 | 11:12 AM
dsalak86's Avatar
dsalak86
so if my injectors are sticking would I smell gas?
Old May 11, 2022 | 11:43 AM
master tech's Avatar
master tech
Site Moderator & Tech
Not really. Just you mileage would drop and may get a slight misfire if the injector is sticking. Because lack of fuel. If you think you have sticking injectors. Add some fuel injector cleaner to your next fill up.
Old May 11, 2022 | 02:32 PM
dsalak86's Avatar
dsalak86
I have and it’s still at -23 long term fuel trim
Old May 11, 2022 | 06:13 PM
jrsick's Avatar
jrsick
Have you looked at your plugs? They would tell you if you have a lean condition, and which cylinders are affected.
Old May 13, 2022 | 08:46 AM
dsalak86's Avatar
dsalak86
What if the plugs are dry ?
Old May 13, 2022 | 02:19 PM
jrsick's Avatar
jrsick
Champion auto parts has a good site for reading spark plugs. I would expect the plugs to be dry; it's the color and burn pattern that you are checking.
