07 ram 1500 4.7l. bank1/bank2
Old Aug 14, 2022 | 12:23 PM
FatherTimE714's Avatar
FatherTimE714
Something is up on bank 1. The graph for O2 sensor voltage is not what I would expect. (sensor 1) Should look more like bank 2 sensor 1.
Any misfires showing up? Bank 1 is running REALLY lean.
no misfires that's I've seen. These are what FIXD app and Innova 3100RS scanners show.
FIXD:
This is INNOVA 3100RS
Old Aug 14, 2022 | 12:30 PM
Ah, so the PCM is thinking S1 and S2 are swapped, not left to right. Looking at the readings, that is a reasonable conclusion. Where are the connectors for those two?
Old Aug 14, 2022 | 12:38 PM
FatherTimE714
All 4 sensors are the same product #. I've switched them literally to every position. Same results
Old Aug 14, 2022 | 12:46 PM
FatherTimE714
Connectors themselves are located on either side of the engine.
Old Aug 14, 2022 | 01:39 PM
Moving the sensors from hole to hole won't matter, if the sensor itself is ok. It's the other end, the connector, that the PCM is whining about. It seems to think you have sensor 2 plugged in to where sensor 1 should be, and vice versa.
Old Aug 14, 2022 | 02:04 PM
FatherTimE714
Wow, so maybe on the engine swap they crossed the connectors from PCM to sensor connection? I didn't know that was possible. Or even if they had enough line to cross them.
Old Aug 14, 2022 | 02:35 PM
Yeah, I don't know where the connectors are, but, I think it's worth a look.
Old Aug 17, 2022 | 08:15 PM
FatherTimE714
Well "Mr.You", the check engine light just turned off today. We drove it straight to smog test and passed both tests. Tags paid and vehicle is no longer PNO. Its been anywhere from 105°-110° the past few days so I didnt even have a chance to check crossed wires/o2 connections. I believe the advice you gave about the Denso o2 sensors did the trick! Absolutely amazing 👏. I will keep an eye on it and keep you posted if anything should pop up. Thank you brother!
Old Aug 17, 2022 | 08:57 PM
Happy to help.
