48RE overdrive housing
Old Jan 21, 2023 | 09:48 PM
dumontkid's Avatar
dumontkid
Default 48RE overdrive housing
ANYBODY KNOW THE DIFFERENCE BETWEEN THE 05093166AA and the 05093166AB? did they make changes to the later?
Old Jan 22, 2023 | 12:33 AM
fj5gtx's Avatar
fj5gtx
Usually that just means they made some minor change to the part. Might have been forced by supply chain changes, or minor engineering update. In general the component should be a direct fit.
Old Jan 22, 2023 | 02:26 PM
dumontkid's Avatar
dumontkid
I agree, but if it isn't significant i can save money and buy the AA version.
Old Jan 22, 2023 | 02:42 PM
It is the revision number. What actually changed is anyones guess. The AA will work perfectly for you.
Old Jan 23, 2023 | 10:58 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Just the evolution of the part number. Might have changed manufacturer, or a small material change. Very rarely is it not completely interchangeable.
Old Jan 23, 2023 | 07:13 PM
dumontkid's Avatar
dumontkid
I ask because the AA must be susceptible to cracking (assuming it was the original part number) and whether or not the AB was modified to reduce cracking.
Old Jan 24, 2023 | 01:50 PM
dumontkid's Avatar
dumontkid
I ordered one out of McKinney Texas dodge $450. my local dealer wanted $750. we will see what we get this time,
Old Jan 25, 2023 | 07:54 AM
fj5gtx's Avatar
fj5gtx
Ok, interesting problem, did a quick search... found this precision video (below). Host implies the case is available aftermarket. Looks like an easy swap over into a new case, and the snap ring groove seems to be a problem (some kind of aftermarket kit to extend the life).
