O4 Cummins lope at idle
Old Jun 4, 2025 | 10:32 PM
Goshdarnram's Avatar
Goshdarnram
Default O4 Cummins lope at idle
Hey I have a 04 cummins ram 2500 300k miles it has a lope at idle when the motors cold (can be 80 degrees outside) and it will lope when warmed up it's fine. No blow by no smoke nothing but the lope has me worried about injectors. I put a brand new fca on it and it still does it. Never been tuned or anything
Old Jun 5, 2025 | 12:59 AM
Prismatic's Avatar
Prismatic
When's the last time you changed the fuel filter and air filter?
Does the lope happen at idle in park, in drive? All gears?
Does it lope with the AC off?
Does it happen when you put it into park from drive?
Check engine light on?
How old are the batteries?
Old Jun 5, 2025 | 05:53 AM
Goshdarnram
Batteries are brand new 2 AGM ones fuel filter 2monrhs old same with oil AC off it'll do it, no lights, haven't tried it in gear but I've only noticed it in park it's an auto aswell, sorry should have included that, air filter I haven't checked to be honest I planned on going with a s&b eventually
Old Jun 5, 2025 | 05:57 AM
Goshdarnram
The lope also isn't consistent like it'll lope then for a second it'll stop then lope again but it don't lope every time either
Old Jun 5, 2025 | 07:23 AM
dodgetruck2's Avatar
dodgetruck2
Can you post a video? Is it an early 04 or late 04?
Old Jun 5, 2025 | 07:01 PM
Goshdarnram
I'll try it's a early 04
Old Jun 5, 2025 | 07:13 PM
Goshdarnram
Old Jun 5, 2025 | 07:26 PM
dodgetruck2
What are you running for a tuner? Do you have a gauge to read rail pressure/cmd rail pressure? Whats lift pump pressure?
I would lean towards a fuel pressure issue first, either FCA or maybe the relief valve. Could do the relief test too
Old Jun 5, 2025 | 07:57 PM
Goshdarnram
I put a rail plug in it and just put a new fca in it I don't currently have a gauge
Old Jun 5, 2025 | 07:58 PM
Goshdarnram
No tuner
