Lighter Not working!
Old Feb 24, 2006 | 06:27 PM
swanner's Avatar
swanner
Default Lighter Not working!
I have an 02 4x4 QC 1500,
the lighter in the dash has no power, checked the fuse, and it's Ok, even replaced the fuse. Still no pwer.
Any Suggestions?
P.S. The same thing going on in Wife's car. 02 Intrepid ES. No lighter power (FUse OK)
Old Feb 24, 2006 | 06:35 PM
MGDMike's Avatar
MGDMike
Default RE: Lighter Not working!
Do you think its just lighter itself...go to Target/Walmart or whatever and get a $3 lighter and see if that helps. Weird problem?
Old Feb 24, 2006 | 06:38 PM
tamuccmike's Avatar
tamuccmike
yea...i had the same problem..after toking a few cartons of marlboro menthols...but i do not smoke in my truck anymore...either get the unit replaced...or better yet, don't smoke
Old Feb 24, 2006 | 06:39 PM
swanner's Avatar
swanner
Thought about that, but it's not the lighter. Cell phone does not work in it either, I've even stuck a test light in there and no power.
Old Feb 24, 2006 | 06:45 PM
Sam!'s Avatar
Sam!
My 02 Wasn't working either. for some reason it was just disconnected removed the drivers side cover under the steering column and reached in and connected it. fixed and only works with the Ign key on or acc.
Old Feb 24, 2006 | 06:51 PM
swanner's Avatar
swanner
Thanks, Going to check it out now..
Back in a while..
Old Feb 24, 2006 | 07:26 PM
swanner's Avatar
swanner
Sam!----YOUR A GENIUS..........It worked, Little trouble figuring out how to remove the cover, but thanks........
A MILLION
Old Feb 24, 2006 | 07:47 PM
MGDMike's Avatar
MGDMike
That was it!! Thanks for the good gouge man! Bravo Zulu! (<-Navy talk for good job!)
