4.7L Stalled this morning need help
Old May 4, 2006 | 10:28 PM
Squirrel508's Avatar
Squirrel508
Default 4.7L Stalled this morning need help
My 4.7 stalled this morning when i was pulling out of the driveway it is an automatic. Do any of you guys know what it is ? Please let me know what part it is or what the dealers have said to yall. It was just started i backed up and when I got to the hill to pull out it just killed on me. It is an 05 with 8500miles and I bought it 6 months ago so Im pretty pissed off
Old May 4, 2006 | 10:43 PM
Gone Fishin's Avatar
Gone Fishin
Default RE: 4.7L Stalled this morning need help
The first thing to do is run it back to the dealer so they can look at it and a problem has been generated with your truck. Seems that a number of folks out there have been having stalling problems. Do a search and I'm sure you get many hits. If something like a recall or TSB comes out, you have already registered the complaint with DM. I've never had mine stall other than letting the clutch out too fast, but thats my story.
Good Luck, I'm sure you'll a few replies
Old May 5, 2006 | 02:09 AM
arrowman's Avatar
arrowman
My 4.7 stalled or ran on 4 cyl often... I ran the gamut of DIY attempted "fixes"... Tried 89, tried injector cleaner, checked my voltage, check the a/c clutch, you name it. Finally I got wise and ran to the dealer... Fortunately I was under warranty, they replaced the fuel pump, ecm, plugs, and coils... Ran fine afterwards.
Unfortunately it threw a cv joint a month later, followed shortly by the sway-bar linkages.... Traded it last Friday on an 06 with a Hemi and laughed all the way home.
Old May 5, 2006 | 11:57 AM
RAMANATOR's Avatar
RAMANATOR
I HAVE AN 03 4.7 WITH 50,000 MILES DOING THE SAME THING. IT HAS HAPPENED 3 TIMES NOW. DEALER TOLD ME I JUST NEED A TUNE UP SPARK PLUGS THRTL CLEANING ETC. WHICH I THINK IS B/S. I HAVE ALSO HEARD OF SOME DEALERS CHANGING OUT TORQUE CONV. PLEASE POST BACK AFTER TRIP TO DEALER
Old May 5, 2006 | 12:16 PM
manatlarge2's Avatar
manatlarge2
man that sucks....Thought they worked the bugs out of the 4.7 already. My '02 did the same thing..it turned out to be a bad fuel pumpand something about the fly by wire TPS sensor was faulty but that fixed it up right...hope its something simple..but i would let the dealer fix it its under warranty.
Old May 6, 2006 | 01:15 PM
Squirrel508
The dealership said it might be a camshaft sensor.
Old May 9, 2006 | 01:10 AM
Squirrel508
Talk to dealership today they said that the computer somehow lost the memory for the crankshaft position sensor and they reset the pcm
Old Jul 15, 2008 | 10:41 PM
Squirrel508
just to let yall know the above post did not work.. so still open for ideas maybe plugs and wires and fuel filter??
Old Jul 15, 2008 | 11:26 PM
mmstar23's Avatar
mmstar23
mine use to do it. what the dealer said about plugs and cleaning the throttle body IMO was corrrect. i put new NGK's in it, cleaned the throttle body and jiggled the wires on the TPS. disconected the battery for a little bit and it was all good from there. good luck
