Anyone here have thier Hemi Ram cammed?
Old May 18, 2006 | 09:13 PM
  #31
Nicky B's Avatar
Nicky B
Default RE: Anyone here have thier Hemi Ram cammed?
ORIGINAL: HemiJT
The cams from KRC are comp cams but with krc's custom grinds.
The KRC 210 and 218 cams are drop ins. You won't need any programming. (These are similar to comps 3 cams for the hemi)
The KRC 220 cam (larger than the comp 273) will require the use of an Apexi SAFC2 or a SMT6, something you can adjust fuel injector pulse at certain vaccum levels and timing or you can go full standalone as comp did with their 273. My air fuel ratio sat between 12.0 and 12.5 at WOT from 4500rpms to 6250rpms with the 220 cam and stock injectors with a little tuning. On KRC's dyno the 220 cam in my truck showed a 54rwhp gain, and that was a 2nd gear pull, with my 22's on, the exhaust cutout closed, a new high stall tc and 4:56 gears (all of this will cause lower dyno #'s) Now I've removed the KRC 220 cam from my truck and now I'm going with the KRC Turbo Cam - 228/224-554/547 115+4 - This is better since it's got the turbo now.
The SMT6 can adjust timing and will let you write your own fuel maps so with it you can fix any timing or fuel problem the cam may present for a lot less than the cost of a standalone FAST. I'm using the SMT6 on a 2 Bar MAP Sensor to tune my turbo hemi ram. I'm also using 55lb injectors and an Aeromotive billet EFMU for fuel. Still debating if we're going to turn it to a return style fuel system. That'll depend on how it does when the motor comes back from getting the forged bottom end. SHould be pretty cool.
You said just the 220cam gave you a gain of 54HP. So what would the 218cam give me like 30-40HP or so. So with headers I'm looking at around 50-60HP gain. All for about a grand thats great! Along with a CAI, superchip, and 4.10gears I should be able to beat lightnings right? And then with nitrous beat modded lightnings.
Old May 18, 2006 | 09:49 PM
  #32
SRT10KLLR's Avatar
SRT10KLLR
That dyno was a 2nd gear pull so your numbers might be higher or about the same but with the 218. One thing though, not all trucks perform the same given the same mods so you will not know for sure until you put the cam in.
Old May 19, 2006 | 04:52 PM
  #33
Nicky B's Avatar
Nicky B
ORIGINAL: SRT10KLLR
How do you do a 3rd gear pull? Cause the top of second 75mph. After 80 or so the ram's are pretty slow.
Old May 20, 2006 | 02:53 AM
  #34
SRT10KLLR's Avatar
SRT10KLLR
You need to use the "key trick" or Superchips to due a third gear pull without getting into the speed limiter.
Old Jul 21, 2006 | 05:01 PM
  #35
Nicky B's Avatar
Nicky B
Does anyone here know if I'll any problems with the computer after the 210 krc cam I decided to go with as been installed? I know in the thread the answer has been no but I just want to make sure.
