Engine and ETC light/ truck stalling, need help!?
Old Mar 10, 2007 | 10:55 PM
Javier0351's Avatar
Javier0351
Default Engine and ETC light/ truck stalling, need help!?
I have a 2003 Dodge Ram 1500 w/ Hemi. But my engine light along with a blinking ETC has appeared on my dash. The truck has staled on me several times especially when im taking left turns. It becomes very sluggish and itidels alot. Im also getting a P2175 and P2106 code. Can anyone please help or decipher these codes? If so please help me out.
Old Mar 11, 2007 | 10:34 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Engine and ETC light/ truck stalling, need help!?
P2175 Throttle Actuator, low air flow detected
P2106 Throttle Actuator, Forced limited power
Sounds like the engine is starving for air.
Old Mar 12, 2007 | 04:08 AM
Javier0351's Avatar
Javier0351
Thanks for responding!! What do you recommend I do??
Old Mar 12, 2007 | 02:53 PM
crashedcdo's Avatar
crashedcdo
could it be as simple as a dirty air cleaner?
Old Mar 12, 2007 | 08:41 PM
kenihemi's Avatar
kenihemi
You can try resetting the pcm and see if it returns.
If it does, then check the connector at the throttle body.
If that don't work, its dealer time.
Old Mar 13, 2007 | 03:01 PM
Javier0351's Avatar
Javier0351
This is probably a dumb question, but where exactly is the throttle body located at? And how do i reset the pcm??
Old Mar 13, 2007 | 04:40 PM
kenihemi's Avatar
kenihemi
The throttle body is in the center/rear of the top of the engine. The airbox and hose feeds into it.
But, your problem could also be the electronic thottle assembly below and just behind the battery.
To reset the pcm, look at the underneath of your fuse box lid and find the number of the fuse for the pcm/skim.
Pull that fuse, buckle the driver seat belt and turn the key to start (it won't start) and wait for 2 chimes. That will reset the pcm and trans.
Old Mar 19, 2007 | 09:38 PM
Javier0351's Avatar
Javier0351
I reset the pcm and at first the truck kept turning off on me. Once i got on the road it was fine for a day or two then back to the norm. Idles, stalls and at times it accellerates on own.
Old Mar 19, 2007 | 10:13 PM
kenihemi's Avatar
kenihemi
Dealer time.
Old Mar 20, 2007 | 03:00 AM
Javier0351's Avatar
Javier0351
Someone told me that it could be my O2 sensor. If so could that be something i can do myself if so where is it located? What do you think?
