Pacesetter LT headers DIY
Old 05-02-2009, 11:27 PM
AF_HEMI's Avatar
AF_HEMI
AF_HEMI is offline
Default Pacesetter LT headers DIY
Finally got my LT headers installed today. Decided to do a quick write-up about since there wasnt one yet. Sorry for the crappy pics, had to use my phone cause i'm an idiot and didnt charge the camera battery. If you have any questions, feel free to PM me.
1. Remove the 11 screws holding on the wheel well liner and remove the liner. Before you can pull it all the way out, there is a plastic clip holding some wires. pull the clip out of the back of the wheel well liner.
2. remove the 4 nuts holding on the aluminum heat sheild.
3. Remove the 8 manifold bolts. CAUTION: do NOT force them! If you even BEGIN to shear one off you're in a world of hurt. If you feel it start to seize up, spray some wd-40 or pb blaster in there and re-tighten. Then loosen it again. If it still sticks, spray again and tighten. By loosening and tightening, you're allowing the lubricant to soak into all the threads.
4. Loosen the two bolts connecting the manifold to the pipe. Remove manifold.
5. You'll need to figure out a way to get the exhaust back to the muffler out. You're not gonna need it, so hack away. I wasnt positive the setup was going to fit, so I kept everything in tact until I was sure it was going to work.
6. (4x4 only) Its possible you'll need to disconnect the front drive shaft to allow the old exhaust room to get out, and room for the new headers to slide in. Remove the 4 bolts holding on the front drive shaft (at the front yoke). Tip: either use an impact wrench or put the truck in 4x4 to keep the driveshaft from turning.
7. Once old exhaust is gone, test fit new headers. Its a tight sqeeze, but they will squeeze up there. To fit the passenger side, you may need to trim a small tab off the transmission bell housing to prevent rubbing on the header. A hack saw will take it off in about 3 minutes due to the soft metal. Cut right through the bolt hole (about 3/4" off). I cut a small peice of aluminum out of the old manifolds heat shield to cover the hole that will appear when removing the tab. I just tacked it in place with some jb weld. there is no reason other than to keep dirt out of the bell housing. Leaving the small opening there wouldnt really hurt anything.
8. Remove headers. (optional: plug exhaust chambers. Do NOT use paper towels or anything else that will leave dust/debris behind) Get some sandpaper (roughly 150 grit) and start sanding. Make sure to get off all carbon deposits (black stuff) and everything else not bare metal. The heads should be shiny when you're done. (the wet spots in the pics are wd-40 overspray from removing bolts before).
9. Spray some wd-40 on a rag and wipe down the heads to remove any leftover dust. DO NOT use an air hose to blow dust off. Doing so will cause an excess amount of debris to go into the exhaust chamber.
10. Put headers back in, line up, and put the new gasket in place. Be careful not to damage the gasket. Start putting bolts in finger tight. Do NOT torque anything yet.
11. Once all bolts are finger tight, torque the bolts to 23 ft lbs (or as otherwise instructed) going from inside out (see picture)
12. Once tight, start engine and run for 3-5 minutes. Allow headers to cool (blowing compressed air on them helps speed the process). Go back through and retorque.
13. If you choose to remove catalytic converters, see DIY "how to remove CEL light when removing cat". If you decide to keep your cats, you'll need to fab up a new y-pipe as well as extend your rear o2 sensor wires about 18". I used the y-pipe kit from moesperformance. its also jet hot coated and everything fit together perfectly...the way pre-bent stuff is supposed to be.
14. Once everything is in place, go back and double check all bolts are tight. If you disconnected the drive shaft, reconnect it.
15. Put the wheel well liners back in and tighten all 11 bolts.
16. Start engine, rev engine, listen to your HEMI purrrrrr.
Expect this install to take all day. Ideally, you will have 2 people. It took me about 6 hrs with a buddys help. If you're by yourself, good luck...
Old 05-03-2009, 01:28 AM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
Nice write up. I found one error though:
8. Remove headers. (optional: plug exhaust chambers. Because they are hydrolic lifters, all exhaust valves will be closed, preventing anything from getting in the combustion chamber. ).
Yes these, like most all modern engines use hydraulic lifters, but the valves stay open when the lifter is up on the cam lobe whether the engine is running or not.
Old 05-03-2009, 01:35 AM
AF_HEMI's Avatar
AF_HEMI
AF_HEMI is offline
hmmm... i looked inside every port and it really looked like all 4 exhaust valves were closed (unless i wasnt actually looking at the exhaust valve). either way, thanks for pointing it out. It wasnt important, so i just deleted it.
Old 05-03-2009, 04:19 AM
04-fourseven's Avatar
04-fourseven
04-fourseven is offline
Nice writeup, I guess its safe to say youve got your headers in huh? lol
how do you like em?
Old 05-03-2009, 11:48 AM
Cheeech's Avatar
Cheeech
Cheeech is offline
My experience has been with Ford's. Sorry...
But with the Fords, they need to be re-tuned when LT's are put on or they run pig rich. How do the Dodges run with LT's? Could I just run with my 91tune from diablo and still be good or will i need to have Diablo create a custom "canned" tune for a safer bet?
Install looks sweet bro. Like it alot. How much for parts and where did you get them?
Old 05-03-2009, 12:54 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
I run mine with a Superchips set for performance which advances the timing a good bit, promoting more of a lean mix. The balance between a canned tuner set for performance should keep you at a pretty good ratio.
Although, a custom tune is never a bad thing...
Good write-up AF, I put a copy of it in the FAQ section, but left this thread here for comments by your peers, since the FAQs are locked...
Old 05-03-2009, 01:18 PM
AF_HEMI's Avatar
AF_HEMI
AF_HEMI is offline
how do you like em?
i LOVE em! man what a difference... not only do they look sick, this truck sounds 10x better (even with the magnaflow i had before). I have to be careful at stoplights...this think has so much off the line now even without meaning to, its possible i might be plucking some cars out of my grille in the future.
Cheeech,
Im not sure how its supposed to run (smooth like before or kinda rough idle). Either way, the idle is fairly choppy, very similar to what drag cars have but not quite that extreme. Under throttle its real smooth, just louder and a LOT more power. I'm using the superchips 3815 along with several other mods to trick the engine into running a little leaner (180 tstat for example). I still have the CEL from removing the cats, so i'll try to figure that out today or tomorrow. I'm not sure if the rougher idle is because the computer doesnt know what the heck I did to it, so we'll see.
Old 05-03-2009, 01:29 PM
HammerZ71's Avatar
HammerZ71
When I put mine on, I don't think it got any louder, but the tone certainly changed, sounds more like a vintage 60's muscle V8 from the track now...
Although I'm not long away from a muffler change. I'm getting really tired of my close to 5 year old Flowmaster 50HD. I'm going to wait to hear Pyro's Cherry Bomb Extreme and then decide on that or the Vortex and weld it on. Should get a good bit louder then...
Old 05-03-2009, 08:38 PM
sublimedude's Avatar
sublimedude
sublimedude is offline
do you think this would be the same way to take the headers off of a 4.7 v8 or do u think there is another step id have to do?
Old 05-03-2009, 09:40 PM
4.7Ram5.7Rango's Avatar
4.7Ram5.7Rango
4.7Ram5.7Rango is offline
hell of a writeup AF. Pretty detailed and the process seems straightforward. I really wish I could do lt's on my hemi, but its a bit tighter in the durango then it is in these rams (tighter than a gnats ******* to be exact). Im not even sure how Im gonna go after the plugs in that thing, much less lt's.
I x2 the guy above, is the process pretty much the same for the 4.7's? Id imagine so, just with more room to work with. Ill probably never go this far with my ram, just seems pointless on the pre-'08 4.7's......
Quick Reply: Pacesetter LT headers DIY
