Best Bulbs out there.
#21
Hey LU229. I took your advice as well and adjusted the lights up 3 turns and it did make a good bit of difference for me. Just waiting to see how the oncoming traffic handles it. I livve in the Boonies so cresting hills with oncoming cars gets you an eye full of headlight when you are not expecting it. If I get too many high beam flashes I'll turn it down one notch. I noticed a difference before hand when I had a full load of fire wood in the back when driving at night. Makes sense to adjust them up a bit.......
#22
I found a good solution that worked great for me. I didn't want the HID lights either, so I went with PIAA xtreme white bulbs for the low beam H11.
and then got some Phillips 9011 HIR 1 bulbs for the high beam. WOW! what a difference, the high beams put out twice as much light as the stock bulbs did. the PIAA's are noticibly better than stock but maybe 40% brighter. But the Phillips HIR (Halogen Infrared Reflective) are just amazing, and much cheaper than going HID. I got mine on Amazon but you can also get them from candlepower.com or HIRheadlights.com . check it out these things are killer! same wattage but up to 110% more light, best alternative to HID in my opinion.
#23
Yes I have the gorecon.com headlights on my truck with hid in the projectors. The black truck pictured on their site is actually my truck. I have a pair of 6" hid spotlights on my bullbar and hid in the fog lights and its plenty. My highbeams are still piaa's xtreme white with a blue tint wwinder hehe, but I literally don't use my highbeams because it don't make a difference with the hid's on, also need them for driving lights in canada.
#24
The amethyst blue coating on a Silverstar Bulb, does not make it blue light. It actually filters out unwanted colors, to make the light more white. The color of the light emitted is actually very close to daylight. Which is why reflectivity of the lit object is so good. Look at a Silverstar bulb, and that white light will burn into your eyeballs. No doubt as to the color.
Because of this, Silverstar bulbs are the bulb of choice for long distance motorcyclists.
#25
Sorry, I should clarify. On each fender there are only two holes, one elongated and one circular with an adjusting screw. Hence each side has an adjusting screw which I used to raise the lights three turns and it makes a good difference on the backroads at night. I like the white of the Silverstars better than the stock yellow and as mentioned they give a better shoulder view. With the adjustment I'm close to what I wanted for distance without anyone flashing lights at me. So thanks for the tips but I'll still be looking at a different solution in the future. I may consider Silverstars in the future if they offer the ultras for the H13s.
#26
I`ve done my homework, and putting blue coating on a regular bulb actually reduces light output.
#28
Take a look at this link and see what you think www.hirheadlights.com
#29
#30
