Clarity on Ipod Integration w/ Factory Radios
Old 01-25-2009, 08:51 AM
MisterScott's Avatar
MisterScott
MisterScott is offline
Default Clarity on Ipod Integration w/ Factory Radios
Okay. I have a myGig. If you have a myGig all you need is a cable that plugs into the back of your radio. Too the dealer 4 weeks to figure this out. I'll post the part number later today.
For those with other radios, you will need a different cable and module.
I had mine installed (you can do it yourself, but since the dealer screwed everything up, they did it for free) on Saturday and it works great.
However, the idiot installer took 2.5 hours. Honestly, really!
Also, I have discovered that all of the left speakers in my truck don't work now. I am going to pop the dash off this afternoon and re-seat everything and see if it works then.
Old 01-25-2009, 12:17 PM
Vector02's Avatar
Vector02
Vector02 is offline
I ordered my iPod integration cables this week off of ebay for $87. From diagrams I've seen, it just looks like a plug and play system.
Mopar part #82211853
Old 01-25-2009, 01:21 PM
blue2050's Avatar
blue2050
blue2050 is offline
Hello Mr. Scott
If would explain a "popping off the dash" This 2009 does not look so easy. You said you figured it out earlier...share with us that are wary....me.
Cheers
Blue
Old 01-25-2009, 01:27 PM
Vector02's Avatar
Vector02
Vector02 is offline
Originally Posted by blue2050
Hello Mr. Scott
Cheers
Blue
Search is your friend.
https://dodgeforum.com/forum/4th-gen...h-removal.html
Old 01-25-2009, 07:27 PM
MisterScott
The part number 82211853 is it for those with my gigs.
There is another thread on removing the dash. I will caution again, you need to pop the over that surrounds the 110 volt plug. Do that by inserting a flat head in the slot BELOW the plug and pull up which should pop the bottom off. Then pull with some equal force to ge the whole thing off. There is a torix bit behind it.
Remove the chrome flashing around the shifter if you have a lower center consol.
Remove the rubber liner in the foward tray of the lower center consol.
Remove the two phllips head screws below.
Remove the lower center consol by pulling up
Remove the rubber mat on the top tray on the upper center consol.
Remove the two torix bits.
Remove the plastic tray.
Remove the torix bit describe above holding the 110 volt plug.
Gently begin to pull the upper center consol dash piece off.
Remove the electrical connectors for the everything below the radio.
Assembly is the reverse.
Old 01-27-2009, 10:02 AM
Vector02's Avatar
Vector02
Vector02 is offline
I installed my iPod integration yesterday. Took about 20 minutes and works like a charm!
Old 01-27-2009, 11:04 AM
Kneedragger's Avatar
Kneedragger
Kneedragger is offline
87 $ to plug in a 140$ iPod ? can you watch videos ? Why not use the line in jack ?
Old 01-27-2009, 11:16 AM
MisterScott
The beauty is you can control all the ipod functions from the touch screen and the steering wheel controls. You could certainly do it through the Lockpick video inputs or another input source. You cannot view video that I am aware of through the OEM cable.
Old 01-27-2009, 02:07 PM
Vector02's Avatar
Vector02
Vector02 is offline
Because using a line in cable to plug your $140 iPod into your $45,000 truck looks unfinished and cheap.
Hiding the iPod properly and having integrated controls on the nav system is much cleaner and more functional. Plus, your iPod charges when your vehicle is on.
PS. The "$" goes in front of the number, and you don't use a space in between your last letter and the punctuation that ends the sentence.
Edit - So I was a little rough on the guy at first...
Old 01-27-2009, 03:49 PM
Kneedragger
I rather be unfinished and cheap than impolite and rude to a fellow dodge owner.
Sorry if my first post ruffled your feathers !
PS : with such impressive grammatical skills , you must be a devil with the ladies...
Quick Reply: Clarity on Ipod Integration w/ Factory Radios
