Old Aug 5, 2015, 08:24 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
For those who's key fob stops working....
Old Jul 30, 2009 | 08:08 PM
  #41
Ironsides's Avatar
Ironsides
Originally Posted by Stonewhiteram
I drive many highway miles for work. This problem seems worse when I have been on the road for a several hours non-stop.
+1
I've noticed this too. I wonder if it's a heat issue.
Old Jul 31, 2009 | 12:51 AM
  #42
renos09's Avatar
renos09
Can it be a relay not energizing? or more of an antenna issue?
Old Jul 31, 2009 | 08:39 AM
  #43
tadst34's Avatar
tadst34
Default speaking of...
In a similar issue, i have the same problem with the garage door openers. I have to press the button several times before it works.
Sorry to steer the conversation.
I think the key fob issue has something to do with the relay(as stated by someone else). It must not just be the fob because some of us are having problems with the button inside the door as well.
I am sure the dealer knows absolutly nothing about this. They don't seem to know much of anything these days.
Old Jul 31, 2009 | 05:33 PM
  #44
savage_46's Avatar
savage_46
Originally Posted by my05_hemi
Mine does it often. Do have remote start.
I have access to a starscan and do see some key fob dtc's set every once in a while. I don't recall now what exactly the code was. If I get a chance I'll look this week.
mine had a DTC awhile ago for RKE 2 battery low. didnt get a chance to see which RKE my main one is (1 or 2). im pretty sure the low battery is why my truck intermittently doesnt respond, and could be the same for everyone else here.
Old Jul 31, 2009 | 09:17 PM
  #45
CJDTAUTOTECH's Avatar
CJDTAUTOTECH
Its a issue with no response for the door modules I had 2 codes in my truck for it cleared them and so far it has not happened since , Im sure they will have a door module flash soon like I allways say email them and put presuure on them to fix it , Its a software issue they have to fix
Old Aug 2, 2009 | 04:28 PM
  #46
Brummo's Avatar
Brummo
Mine just friggen did it again,damn....
Old Aug 4, 2009 | 03:48 PM
  #47
joker055's Avatar
joker055
Default Key Fob
No remote start with mine, and I have the key fob issue 1-2 a week. No rhyme or reason to help me figure it out either. Happens at random times in different places.
The other day I opened the drive door and locked the truck manually. After that both buttons worked fine. I've also tried hitting the "panic" button which also did NOT work...
Could the battery life just not be that good in these fobs?
Old Aug 4, 2009 | 10:26 PM
  #48
Brummo's Avatar
Brummo
I doubt it has to do with batteries, MO. Mine has been doing this on and off since bought the truck in March. Next time it goes in for service, it is going to get looked at though. I have never replaced the batteries in either remote and about 99% of the time it is flawless. I just acts up when you never want it too.
Old Aug 5, 2009 | 10:47 AM
  #49
tadst34's Avatar
tadst34
Default In the shop
Hello all.
I took my Ram in today for an oil change, the 09-020 recall, and told them to look at the key fob problem.
As I was waiting for the shuttle to take me back to work, I saw them try to get into my Ram. The key problem happened so she had to remove the vallet key to unlock, which then set the alarm off.
I am willing to bet that they tell me that they couldn't find anything wrong with the key fob. I'll keep you guys updated. TTYL.
Old Aug 5, 2009 | 11:01 PM
  #50
Brummo's Avatar
Brummo
Originally Posted by tadst34
Hello all.
Hope they have a Good answer/repair for it...
