Stuck in 4th gear
Old Aug 26, 2010 | 09:15 AM
  #41
BigBlueEdge's Avatar
BigBlueEdge
Wow. That's weird. Hopefully they can fix it for you now.
Rob
Old Aug 26, 2010 | 10:53 AM
  #42
05Dakotaho's Avatar
05Dakotaho
I'm confused. I thought that the transmission would be stuck in ERS (4) and the EVIC would show the numeral "4". ERS (4) is actually the first overdrive gear, not second gear as highlighted below.
Page 319 of 2009 owners manual
Transmission Limp Home Mode
Transmission function is monitored for abnormal conditions.
If a condition is detected that could result in
transmission damage, the Transmission Limp Home
Mode will be engaged. In this mode, the transmission
will remain in the current gear until the vehicle is
brought to a stop.
To reset the transmission, use the following procedure:
1. Stop the vehicle.
2. Move the shift lever to the PARK position.
3. Turn OFF the engine and be sure to turn the key to the
LOCK position.
4. Wait approximately 10 seconds, then restart the engine.
5. Move the shift lever to the desired gear range.
If the problem is no longer detected, the transmission will
return to normal operation. If the problem persists,
PARK, REVERSE, and NEUTRAL will continue to operate.
Only second gear will operate in the DRIVE position.
Have the transmission checked at your authorized dealer
as soon as possible.
Old Jan 31, 2012 | 06:38 PM
  #43
ARTHUR SOARES's Avatar
ARTHUR SOARES
New Member
I have that same problem been to dealer many time first they try to say it was after market remote starter but after disconnecting it problem came back then they replace PCM 4 months later problem came back now they want to remove trans replace pump and filter not happy about that .I think it is a control problem not a hardware the trans work fine when not in limp home mode .If anyone has been cured or thru same trouble shoot with dealer please feel free to contact me at my email artsoa@juno.com I really dont want the trans pulled
brought to a stop.
LOCK position.
Old Jan 31, 2012 | 06:45 PM
  #44
ARTHUR SOARES
New Member
Originally Posted by PlmRam
I had the same problem with my 09 Hemi. It was back to the stealership four times in the first month that I owned the truck. Three of the four times I pulled it into the service lane stuck in fourth. The first three times the fix was to merely re-flash the truck. The fourth time I got Chrysler involved (Lemon Law time). This time around they replaced the PCM. 1200 miles later the problem seems to be corrected.
I have read other posts on Dodge websites from folks with this same issue. Replacing the PCM seems to be the ultimate fix for all of us. It's just a shame that it tales a couple of trips to the dealer with a brand new truck, with what is apparently a known problem, to resolve the issue. Other than that, with 2300 miles on the clock, this is the nicest truck that I've ever owned (I've had Fords, one Chevy, and a Gen 3 Ram).
Not sure about PCM fixin the problem i have 2010 with same issue and had PCM replace 4 months ago and now problem is back dealer wants to pull trans and replace pump
Old Jan 31, 2012 | 06:48 PM
  #45
ARTHUR SOARES
New Member
If any one has gone to the end with this problem please feel free to contact me I will be glad to hear the step that you have gone thru I have PCM replaced and now they are throwing a trans pump at it i would rather not have the trans broke into for the pump if that not fixin it so any other idea are welcome!
Old Jan 31, 2012 | 06:54 PM
  #46
ARTHUR SOARES
New Member
Sir have you had your problem cured ? Because I am going thru the same thing dealer has already replace PCM but problem came back now they are going to throw a pump and filter at it .If you any info that could help move this fwd with my dealer feel free to contact me ! !!!!!
Old Feb 1, 2012 | 10:32 AM
  #47
DodgeCares's Avatar
DodgeCares
Arthur,
I could find no service bulletin outlining the problem that you are having. If the dealer is unable to correct the problem on your vehicle I would suggest calling the Chrysler Customer Assistance Center so they can get the Chrysler techs involved with your issue. The assistance center and the Chrysler techs can work with your dealership to help get the issue corrected. Numbers below.
800-992-1997 United States
800-465-2001 Canada
Old Jul 9, 2012 | 10:53 AM
  #48
Atticus's Avatar
Atticus
My 2010 is at the dealership with this 4th gear issue right now. Still waiting to see what they say about it.
Old Jul 11, 2012 | 04:13 PM
  #49
Atticus's Avatar
Atticus
Replaced a solenoid. Took about 4 business days. Hopefully it will work from here on out.
Old Dec 8, 2012 | 05:39 PM
  #50
Zintharr's Avatar
Zintharr
Taking my 2010 to the dealership on Monday for the same general issues outlined in this thread. Thanks you all of you, I will be armed for the "Well..."
I will let you all know how this turns out.
