Stuck in 4th gear
Old Dec 8, 2012 | 08:51 PM
  #51
SDakRam's Avatar
SDakRam
Driving home tonight after work, pulling away from a stop sign I thought I was spinning on ice. Looked at the dash saw the big 4, thought i bumped the shifter, tried to get back to normal. No luck. Guess I will be visiting the dealership on Monday.
Old Jun 28, 2014 | 11:16 AM
  #52
j-rod82's Avatar
j-rod82
I hate to revive this thread, but I now have this problem. Left work yesterday, truck stuggled to accelerate at a traffice light, looked down, and there was the number 4.
Drove it straight to the dealership. I hope its something that is covered under the lifetime powertrain warranty my 09 ram has.
Kinda PO'd here, I'll keep this updated though.
Old Jun 30, 2014 | 09:58 AM
  #53
DodgeCares's Avatar
DodgeCares
Please keep us posted.
Old Jul 1, 2014 | 02:23 PM
  #54
j-rod82's Avatar
j-rod82
Turns out it was the solenoid pack and I IS covered under my warranty. I'm still disappointed this happened at only 86k miles. I don't haul or tow much at all. Load of mulch in the spring and pull a boat 3 miles a couple times a year. Other than that it never has heavy loads.
Old Jul 1, 2014 | 02:36 PM
  #55
BigBlueEdge's Avatar
BigBlueEdge
A solenoid pack sounds like an electrical item. Towing, load, or strain on the drivetrain isn't going to affect the failure of an electrical item. Rob
Old May 21, 2015 | 09:17 PM
  #56
isantana508's Avatar
isantana508
Default joined the club
It just happened to me on my way to its first smog check at 104000 miles, any permanent solution before I take it to the shop?
Old Jul 16, 2015 | 10:38 AM
  #57
minnesotanice's Avatar
minnesotanice
anything new on this.my 2009 1500 hemi did this a few days ago.
Old Jul 16, 2015 | 10:47 AM
  #58
isantana508
It was the selenoid for me, took it to aamco (out of warranty) and 780.00 dls later is working just fine 6000 miles now but seems like it fixed it.
Lack of maintenance seems like it was.
I may just do it myself next time I thought it was a bit pricey for a selenoid and trans service, but that just may be my cheap self talking.
Old Jul 23, 2015 | 11:29 AM
  #59
minnesotanice
Unhappy 4th gear
ok,took my truck into a trans shop that I trust, there wasnt any elec power to the trans.they don't do elec so I took it to the dealer.sais tipm was bad,replaced that,and the shift selonoid was bad.two grand later and im bacxk on the road. ouch
Old Jul 23, 2015 | 12:43 PM
  #60
Pedro Dog's Avatar
Pedro Dog
Are you the original owner? If you are and still have the lifetime powertrain warranty, then the shift solenoid work should have been free.
Here are the trans parts covered
Transmission: transmission case and all internal parts; torque converter; speed sensors; pressure sensors; drive/flex plate; transmission range switch; transmission control module; bell housing; oil pan; seals and gaskets for
listed components only.
