queston for those who got the latest MDS flash
Old Aug 8, 2009 | 11:33 AM
plumcrazy73's Avatar
plumcrazy73
Default queston for those who got the latest MDS flash
Did you have the Fuel Savor LIght before, do you have it now. did your truck come with single or duel exhaust.
Old Aug 8, 2009 | 01:32 PM
ArcticWolf's Avatar
ArcticWolf
Default Answer
What happening is CJDTAUTOTECH posted a thread "Good news flash for fuel saver light". In this thread he states that the 18-019-09 flash allows the fuel saver light to activate on truck with the MDS 5.7 hemi built before 12/08. Later it was discovered that this flash is only working on the single exhuast models, not the dual exhuast. Also this flash is good for trucks that have a certain order code (look in the thread for those codes). What the big question is why doesn't work for the dual exhuast as the program is only reporting that the engine is in 4cyl. mode.
Old Aug 8, 2009 | 02:53 PM
plumcrazy73
I know that I was wanting confirmation from others that it does indeed work on the ones with single exaust and no previous fuel savor light. like it was posted.
Old Aug 8, 2009 | 06:03 PM
jimf5's Avatar
jimf5
I went thru the 9 pages and 88+posts and it looks like the only one it worked on was the original poster.
Jim
Old Aug 8, 2009 | 06:10 PM
plumcrazy73
that is why i am asking this question
Old Aug 8, 2009 | 06:14 PM
tombogue09's Avatar
tombogue09
Has anyone with the single exhaust got this update?
Old Aug 8, 2009 | 06:21 PM
topgun's Avatar
topgun
It may have something more to do with what he said about the config build or whatever it was called. If you remember, there is a thread on here where the guy had his EVIC changed due to a problem and the replacement had the indicator. Might be the software in the EVIC itself.
Old Aug 9, 2009 | 02:44 AM
1954Radio's Avatar
1954Radio
For what it's worth, I bought my truck on 3/6/09 with single exhaust and I haven't seen a fuel saver light ever come on and my truck was built on 2/11/09 in Fenton, Missouri.
Old Aug 9, 2009 | 09:36 AM
plumcrazy73
1954 did you get the latest MDS flash?
Old Aug 9, 2009 | 10:24 AM
topgun's Avatar
topgun
Maybe the option is not turned on because you should definitely have the indicator. Check the setup screen.
Then again, don't you have an ST? So there is no EVIC to have the indicator show up on?
