View Poll Results: Do 2009 owners want a tune and if so, how much are you willing to spend?
I don't want a tune. Stock is fine for me.
7
41.18%
0 - 350$.
4
23.53%
351 - 600$.
4
23.53%
I don't care, give me that tune!
2
11.76%
Voters: 17. You may not vote on this poll
Tuning Teaser/Poll.
i havent used anything but superchip programmers because they can be reset quickly and also have no ill effects when being used with a cai. So a custom tune that would void my lifetime powertrain waranty doesnt sound to feasible.
If you used a Diablo or SCT, you actually hold the stock tune on the unit so you can always flash (reprogram) the PCM back to stock. It takes minutes and you don't mess with PCM cables.
The MAP sensor guys is a load informing sensor based on the amout of vaccuum in the intake manifold the PCM recognizes the load on the engine. 5 volt sensor at idle throttle closed probably 1.2 volts and wide open throttle 4.5 volts and based on load can be anything inbetween. pretty much a bullit proof design chrysler motors has been using for years!
this is how the bully dog works as well.
I am waiting for the diablo. It is handheld, easy to install in minutes (or un-install), and can be used for custom CMR (dyno) tuning as well.
I have found Diablo's on Chrysler products, at least in the past- to be very effective at waking the vehicle up. Stronger shift points, better mileage, substantially reduced torque management. Typically in the 25-35 hp/tq range too as far as increases.
That is exactly what this truck needs. to be woken up--it just doesn't feel like 390 hp/407 tq. especially under hard acceleration
