Leveling kit confusion
Old Feb 19, 2010 | 02:18 PM
  #41
jball's Avatar
jball
Originally Posted by rolltidehemi
Could you give more information on what kits were used and the material they were made of (billet vs rubber, steel).
The kit was steel, and only netted 2 inches of front lift. The kits were ones that were top spacers and a preload spacer that prevented the over extension of the upper balljoint. The top spacer was 1" thick and the preload spacer was 1/2" thick (approximately).
The material choice isn't going to matter... the companies that offer a urethane spacer have metal thread on adaptors that limit how much you can compress the urethane. Their hype about it 'isolates' or whatever else is a marketing gimmick.
I don't think you are going to find a magical solution to this problem with a difference in material choice. The problems not in the strut or spacer (unless it overextends components), but rather in the CV angles / steeper steering angles and more stress on the rack and pinion... Some people seem lucky and have no issues with the kits - other are not so lucky.
Old Feb 19, 2010 | 09:33 PM
  #42
rolltidehemi's Avatar
rolltidehemi
thanks for the information, checked my truck out in lo and high, no problems. I was reading were some have had issues with their stock rides. I would like the mopar 4" but the truck won't fit in my garage. I may just go the bilsteins and level the front out instead.
Old Apr 10, 2010 | 10:49 PM
  #43
Busta1n2's Avatar
Busta1n2
Lord after reading all of this I am more confused and depressed! I have no clue how to do any of this, only know the look I am going for. Where do you guys go to get this stuff done? I just want to throw some new wheels on and a set of 35's and call it a damn day!
Old Apr 11, 2010 | 05:29 AM
  #44
awful knawful's Avatar
awful knawful
I put my Daystar kit on myself in the garage. It was easy, just a few hours.
Old Apr 11, 2010 | 10:40 AM
  #45
Roy444's Avatar
Roy444
No kidding! It sucks that a 35" tire is the best size tires for an offroad look but at an unworthy sacrifice. The only conclusion I can come up with after reading umpteen threads on leveling kits is that there are those with horrible results and those who have no problems, YET. It seems that a leveling kit is just too much of a hassle to deal with. I'll just stick with the biggest tire I can get with stock rims and save myself the headaches of rediculous modifications, warranty issues, ride issues, etc...
Old Apr 24, 2010 | 07:19 PM
  #46
stimleck's Avatar
stimleck
I just bought a 2010 crew cab laramie with the fender flares-i measured from the edge of the rim to the bottom of the fender flare-(wanted to be sure my measurments were exact instead of sing a spot on the tread) the opeening was 14" at the rear and 10 at the front.
My brothers 09 sport looks to be 2-3 inches higher than mine in the front.
Although I only have 700 kms on it I assume the back will settle a bit-could they have set my front end to the 2 wheel drive height?
Could I add a 1 inch spacer without dealing with binding? If so where to get it?
