dash is apart
Old Feb 19, 2010 | 06:25 PM
Doc Fluty's Avatar
Doc Fluty
Default dash is apart
if you ever wanted to take your dash apart.. just take out a few screws and PULL lol
but seriously.. there is a click behind the AC power outlet that is a bitch...
parts got sent off to the painter.. should have then back mon or tuesday... gonna match my hood and tail gate
Old Feb 19, 2010 | 06:30 PM
topgun's Avatar
topgun
I think the hardest part was taking off the trim ring around the shifter. Did you find any tricks for doing that?
Old Feb 19, 2010 | 06:37 PM
Doc Fluty's Avatar
Doc Fluty
i had a foot long flat head screw driver.. a thin version... just stuck it in side ways and pushed in while prying up
Old Feb 19, 2010 | 07:06 PM
72combo's Avatar
72combo
There is a screw in the AC outlet part that has to be taken out is there not, more than a click.
Old Feb 19, 2010 | 07:15 PM
72combo's Avatar
72combo
You can get it from the dealer or online or even at a stained glass store its a nylon tool called a Fid or in auto terms I don't know other than I used to use it for millions of things in the plant from finishing installing trim. Here is what i mean this would be ideal in fact I am gonna order this little tool kit. http://cgi.ebay.com/ebaymotors/4-PC-...s#ht_538wt_939
Old Feb 19, 2010 | 07:21 PM
72combo's Avatar
72combo
In the second picture there is a green plug that is just plugged into the dash, just into a spot for it to fit,its not making an electrical connection just in the plastic to basically hold it there from rattling I am sure, does anyone know what this plug is for? it is a few inches to the right of where the key goes in
You can drive your truck like this but word of warning if you have 4x4 you will be driving in 4x4 without the switch hooked up. We found this out the hard way.
Old Feb 19, 2010 | 07:35 PM
TI 3VOM's Avatar
TI 3VOM
That would be the GNDN plug. Don't mess with it.
Old Feb 20, 2010 | 02:13 AM
72combo's Avatar
72combo
Why an answer like that if you don't know what it is? Goes Nowhere Does Nothing....you are dealing with another Canadian but I guess the BC ones smoke better pot? So do you know or does anyone else know? How about an edumicated guess. (better clarify I know how the spelled educated)
Old Feb 20, 2010 | 02:28 AM
Doc Fluty's Avatar
Doc Fluty
lol.. i didnt know what that meant.. i thought he was saying it was a ground plug... but your definition is waaay cooler
Old Feb 20, 2010 | 03:48 AM
joe_yoh's Avatar
joe_yoh
You did it alone man? congrats. lol
