2011 Outdoorsman.. Wheres my 115v outlet?
Old Dec 28, 2010 | 09:15 PM
  #41
ChryslerTechBC's Avatar
ChryslerTechBC
It looks like your window sticker was on the wrong truck. Chrysler says that you have the basic split bench seat in the front. The 115v outlet is part of the "Premium cloth seats" which include pwr driver seat, fold flat floors, 60/40 rear seat and centre frt seat under cushion storage.
These are all your options
*V9 Cloth 40/20/40 Bench Seat -V3 Dark Slate/Medium Graystone AC1P Outdoorsman Group
ADAP Luxury Group ADBP Protection Group AJBP Remote Start and Security Group
APDP Lower Two Tone Paint CBEP 40/20/40 Split Bench Seat CFMP Rear Folding Seat
CJ2P Supp. Side Curtain Frt/Rr Air Bags CLFP Front Rear Rubber Floor Mats CV2P O/Head Console w/UGDO
DBAC All Automatic Transmissions DGQ 5-Spd Automatic 545RFE Transmission DMHP 3.92 Rear Axle Ratio
DSAP Anti-Spin Differential Rear Axle EVE 4.7L V8 FFV Engine GNCP Sun Visors w/Illum Vanity Mirrors
GNKP Rear View Auto Dim Mirror GNZP Auto Dim Exterior Mirrors GUKP Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors JP8P Manual Adjust Seats LBCP Glove Box Lamp
LBDP Ash Tray Lamp LDAP Underhood Lamp LEBP Ext. Mirrors w/Supplemental Signals
LECP Exterior Mirrors Courtesy Lamps LE4P Black Exterior Mirrors LHEP Rear Dome w/On/Off Switch Lamp
LMEP Halogen Quad Headlamps LNJP Fog Lamps LSAP Security Alarm
MBAP Painted Front Bumper MBCP Painted Rear Bumper MFTP Body Color Grille
MMJP Accent Fender Flares MNAP Black Door Handles MP8P Delete Black-Out Tape
MYPP Outdoorsman Badging NAS 50 State Emissions NFXP 32 Gallon Fuel Tank
NHDP Heavy Duty Transmission Oil Cooler NHJP Exterior Mirrors w/Heating Element NMCP Heavy Duty Engine Cooling
NZDP Next Generation Engine Controller PXR Brilliant Black Crystal Pearl Coat RAAC All Radio Equipped Vehicles
RDDP Fixed Long Mast Antenna RDZP Steering Wheel Mounted Audio Ctrls RSUP Audio Jack Input for Mobile Devices
SCVP Leather Wrapped Steering Wheel SGDP Rear Extra HD Shock Absorbers TTLP LT275/70R17C OWL All Terrain Tires
TZAP Goodyear Brand Tires WLZC All Aluminum Wheels WMJP Center Hub
XBMP Remote Start System XBNP Tip Start XEAP Tow Hooks
XEFP Transfer Case Skid Plate Shield XEUP Front Suspension Skid Plate XFHP Class IV Receiver Hitch
XGDP Universal Garage Door Opener XGMP Tire Pressure Monitoring Display XHC Trailer Brake Control
XKNA Flex Fuel Vehicle XME Under Rail Box Bedliner X9AP For More Info, Call 888-539-7474
X9BP 1-Year SIRIUS Radio Service YGEA 5 Additional Gallons of Gas ZDHP Spring - Left Front
ZDSP Spring - Left Rear ZSHP Spring - Right Front ZSTP Spring - Right Rear
2TTA Customer Preferred Package 2TT 24T Customer Preferred Package 24T 4KZP 4X4 Tracking
These are your standard equipment
BABS 160 Amp Alternator BCVS 700 Amp Maintenance Free Battery BNBS Electronic Stability Control
BRTS Anti-Lock 4-Wheel Disc Brakes CBZS Prem Vinyl Door Trim w/Map Pocket CE8S No Lumbar Adjust
CGDS Front Height Adjust Shoulder Belts CGSS Supplemental Side Air Bags CG3S Advanced Multistage Front Air Bags**
CKES Floor Covering Carpet CSPS Driver/Passenger Assist Handles CUES Rear Underseat Compartment Storage
CV1S Chrome Accent Shift **** DH5S Elec Shift-on-the-Fly P/Time T/Case DJMS 205MM HD Front Axle
DRNS 235MM REAR AXLE DS7S Conventional Differential Frt Axle GACS Tinted Glass Windows
GFES Rear Power Sliding Window GNMS Passenger Side Sun Visor w/Mirror GXMS Remote Keyless Entry
GXXS Sentry Key Theft Deterrent System HAAS Air Conditioning HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation JATS Instrument Cluster w/Display Screen JBYS Instr. Panel Color Keyed Bezel
JCBS 120 MPH Primary Speedometer JFJS Temperature Compass Gauge JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns JJJS 12V Auxiliary Power Outlet JKYS Power Accessory Delay
JPBS Power Locks JP3S Pwr Front Windows, 1-Touch,Up Down LAZS Vehicle Information Center
LETS Traveler/Mini Trip Computer LMGS Automatic Headlamps LPES Cargo and CHIMSL Lamp
MCMS Body Color Upper Fascia MDAS Front License Plate Bracket MGAS Ram's Head Badge
MHLS MOPAR Rear Wheel Well Liners MS2S Ram 1500 Badge MTDS SLT Badge
MUSS 4X4 Badge MXCS Front Bumper Sight Shields NHMS Speed Control
QDMS Mineral Gray Met. Clear Coat RCGS 6 Speakers RESS Media Center 130 CD/MP3
RSCS SIRIUS Satellite Radio SBAS Power Rack and Pinion Steering SFBS Front Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar SHFS Rear Stabilizer Bar SUAS Tilt Steering Column
TBBS Full Size Spare Tire TBMS Tire Carrier Winch WFXS 17X7.0 Aluminum Wheels
WF1S 17 Steel Spare Wheel XA8S Non Adjustable Pedals XBSS Pickup Box
XFKS 7 Pin Wiring Harness XFUS Trailer Tow w/4-Pin Connector Wiring XJJS Locking Tailgate
XJ8S Body Color Fuel Filler Door X81S Instrument Panel Parts Module X82S Door Parts Module
X83S Front End Parts Module X88S Tire Wheel Parts Module YAAS Build To U.S. Mkt. Specifications
Z6GS GVW Rating - 6700# 1AAS U.S. Dealer Retail 142S Zone 42-Detroit
5BAS DS-Vehicle Family 5I4S Four Wheel Drive (4WD)/(4X4) 5UGS 2011 Vehicle Specifications
5ZBS Price Class H 5ZES 6 FT. Cargo Box 5ZKS Quad Cab
5ZLS 1500 Series 594S Vehicle Order Tracking 6USS U.S. Specifications Label
623S Michigan Ship to State Code 7BAS Carb. Code 01 7CFS Smog Code 06
Old Dec 28, 2010 | 11:01 PM
  #42
moosefire66's Avatar
moosefire66
The outlet, among other things is apart of the Outdoorsmans group package, or so it is labeled on my window sticker anyways....
Old Dec 29, 2010 | 11:12 AM
  #43
randomdef's Avatar
randomdef
duh. he just gave you the answer you so longed for (sticker is wrong) and all you do is go back to square one with this silly post (wrong sticker stays the wrong information but I'm gonna claim its correct!).
you don't want help. you want to vent. get a blog.
Old Dec 29, 2010 | 12:44 PM
  #44
HammerZ71's Avatar
HammerZ71
Obviously there is a discrepancy between his actual build sheet and the sticker that was placed on the truck.
Sticker wrong or not, he's entitled to ALL the equipment represented IN WRITING on his sticker. Bring truck & window sticker back to dealer and politely demand EVERY ITEM that is on the sticker. I would...
Old Dec 29, 2010 | 06:02 PM
  #45
Oleksakjr's Avatar
Oleksakjr
No LEGALLY he is entitled to everything on the actual build sheet, and at most an apology for the incorrect window sticker...
The dealer should make things right and do everything they can to help you out, but in the end you may only end up with a new window sticker
Did you even look at the sticker when you purchased the truck? I know you can get caught up in the moment, but damn man some of the stuff on your sticker sounded kindof hard to miss... even as small as the little plug outlet
Old Dec 29, 2010 | 09:22 PM
  #46
canadian dakota's Avatar
canadian dakota
i have the outdoorsman and as for the 115v
665fba82.jpg?t=1293675540
over on the right i didnt ask for this option it just came havent found a use for it yet either also have the 40/20/40 split in the front and 60/40 in the rear and i forget who said it but yes it is the 26T order package in the 1500 as well
Old Dec 29, 2010 | 09:52 PM
  #47
moosefire66
I'm so glad you chimedinwith your $.02 worth of nothing. This "Silly post" Is about my truck being built improperly. I doubt you read all of the posts made here, probably too busy trying to find a way to ensure that others peoples problems seem measly and petty in your perfect world. If you dont like my post, dont bother with a response.
Hammer: I talked to the dealer today. We took my truck to the service department, and verified that all of the things on my sticker should be in fact on my truck. They are going to call the District Manager of the Warren Truck Plant (where the truck was built) and try to figure something out. He states that they will probably buy the truck back, and try and sell me another... Unfortunately this week all (or most) of the plant workers are off of work, so he has to wait until Monday before I will hear anything.
Old Dec 29, 2010 | 09:53 PM
  #48
05Dakotaho's Avatar
05Dakotaho
That is good news. Sorry that a few mal-contents trashed your thread.
Old Dec 29, 2010 | 10:19 PM
  #49
randomdef's Avatar
randomdef
or you could stop crying on the internet.....baby.
Old Dec 29, 2010 | 10:57 PM
  #50
HammerZ71's Avatar
HammerZ71
Show me the law.
I believe that he would be entitled to restitution under the Monroney Act. The build sheet has no bearing as it is not provided nor are it's contents disclosed to the customer at the time of purchase.
The manufacturer and/or dealer can be fined up to $10,000 if there is NO window sticker on the car OR if there is incorrect information on this sticker and if pre-knowledge of incorrect information can be proven, you also have a criminal case of theft by deception. Also, as per the Monroney Act, Caveat Emptor would have absolutely no bearing.
I would imagine that the dealer is offering to buy it back and not just put the items in because by law, the sale was not legal...
And Moose, I'd make them give me one hell of a deal on a new truck if I were you...
