piston slap
Old Jan 1, 2011 | 03:22 PM
zx14k's Avatar
zx14k
Default piston slap
HI i have a klunk klunk klunk........in my 2009 hemi with 12000 miles.it only happen wen the engine is cold. i went to the dealer they keep it overnight to listen at the sound in the morning and tell me it is normal for most hemi and this is not a problem and they call that piston slap or something like that.what do you think. thank
Old Jan 1, 2011 | 04:08 PM
jayman84's Avatar
jayman84
I think piston slap is not normal. Go to another dealership. You could be one of the trucks with the bad exhaust manifold bolts and they need to be replaced. Is it a metal on metal sound or is it more like the sound of an exhaust leak?
Old Jan 1, 2011 | 10:10 PM
POWER SEDAN's Avatar
POWER SEDAN
Piston slap, huh, never heard of that one before, that's a pretty creative diagnosis. Could you somehow record a sound clip for us and upload it?
Old Jan 2, 2011 | 09:12 AM
CarGuyOhio's Avatar
CarGuyOhio
Piston slap is not normal, but they may be not describing it correctly. If a Hemi sits for a long time you could hear some lifter tick for a few seconds. There is a big difference there.
Also what year truck do you have? If you have a 2009 was the exhaust manifold bolt RRT performed?
Last.... Do you do your own oil changes, if so, and even if not, what weight are you, or someone else, putting in?
Old Jan 2, 2011 | 10:12 AM
capsfloyd's Avatar
capsfloyd
with only 12,000 miles on the truck , I would think the ex. bolt manifold has not been done , and I hear the lifters on a cold morning also just a second. My 09 has 82,000 .
" Drive it some, I promise it won't hurt the truck "
Old Jan 2, 2011 | 10:15 AM
zx14k's Avatar
zx14k
yes it is a 2009 and the exhaust was performed.i dont think it is a lifter.the sound is there every time i dont use the truck for 5 or 6 hours (in winter).wen i start the truck the sound is there until the engine reach near normal temperature, after that it is OK.i do my own oil change with lucas syntetyc 5-20
Old Jan 2, 2011 | 10:31 AM
HEMI5150's Avatar
HEMI5150
You`re using LUCAS oil...???
You must not like your truck...lol
Old Jan 2, 2011 | 10:46 AM
zx14k's Avatar
zx14k
what is the best oil to use that i can buy in canada?
Old Jan 2, 2011 | 12:36 PM
Laramie1997's Avatar
Laramie1997
Mobil 1 and Valvoline as a close second.
Old Jan 2, 2011 | 01:00 PM
puggerton03's Avatar
puggerton03
I like to use Pennzoil Platinum 5w-30 Full Synthetic or Castrol Syntec 5w-30. Mobil-1 isnt as good as it used to be.
