Old Aug 5, 2015, 08:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
key fob problems
Old Jul 3, 2014 | 12:20 PM
  #31
mike2810's Avatar
mike2810
My 2009 Ram has had the intermittent issue pretty much sinceI purchased the vehicle. Doesn’t matterwhich key fob I use. Replacing thebattery seemed to help for awhile. Inthe last month I have had 3 episodes of having to push the button numerous timesto get the doors to unlock. Also had asituation where using the door lock switch on the arm rest took a few times toget the lock to engage.
I might bring it up the next time I take the truck in forservice. I will only have them work onthe issue if it’s covered under the extended warranty. After over 5+ years, I have learned to live with it.
Old Jul 25, 2014 | 10:14 PM
  #32
Dodge11's Avatar
Dodge11
Miy fobs do not work at all.Been using the key.Dealer said i need a new WIN wireless ignition node.Does anybody know how to change this?2011 Ram 1500
Thanks
Old Jul 26, 2014 | 11:14 AM
  #33
tadst34's Avatar
tadst34
From another thread;
https://dodgeforum.com/forum/4th-gen-ram-tech/205725-for-those-who-s-key-fob-stops-working.html
Quote:
Originally Posted by tadst34
I've had my truck in the shop 3 times regarding this issue. They never had a fix. I even filed a case with Chrysler twice. Finally, the last time I took it in they told me they found a case in the "star" system with an 09 ram 1500 with the same issue, they said they replaced the TIPM and it has resolved the issue. My dealer ordered the part and I'm gonna have it installed free of charge(because I filled the complaint before the basic warranty was up). Ill let you all know if it works.
Update;
It is not the TIPM
I would like to see it the dealer had a TSB for the 09 like stated earlier in this thread. It would be worth a try. I think if enough people called the recall hotline it might get resolved, but most people just say forget it and live with it.
By the way, I had to press the unlock button 15 times to open just the other day. Really irks me.
Old Jul 27, 2014 | 08:37 PM
  #34
Dodge11's Avatar
Dodge11
Thanks
Old Jul 28, 2014 | 07:01 AM
  #35
Adirondaker's Avatar
Adirondaker
Default Key FOB problems
Had both the fobs replaced on my 2011 RAM back in 2012 (see posts) the old ones are defective. There's an updated fob. My dealer knew nothing of this until I printed & brought the bulletin off this site to them. Never had another malfunction after this...
Old Jul 28, 2014 | 08:51 PM
  #36
WESIDE's Avatar
WESIDE
Any link to that bulletin? I have issues randomly some times and yes it a pita.
Old Jul 29, 2014 | 09:22 AM
  #37
Adirondaker
Don't know if it was actually a bulletin but a memo from Chrysler to the dealers.If I can find it I will repost. Here's an old post from another member talking about this...Old 03-07-2011, 08:44 PM
dizzyttc dizzyttc is offline
Garage is empty, add now
Vehicle: 2009 Ram QC 4x4 Hemi Black
Hey guys, Im in Toronto Canada and have had this problem with the remotes on and off since day one. Last summer I went to the dealer with this problem and of course the remotes worked so the dealer did nothing about. Last Saturday I decided to go back to the dealer with this remote problem and to my surprise the dealer told me that Chrysler knows of the problem with the remotes for the 09 ram and that they now use a different manufacturer. The dealer programmed two brand new remotes for me under warranty. So far so good.
Old Jul 29, 2014 | 10:15 AM
  #38
tadst34's Avatar
tadst34
Just google
Dodge tsb 08-010-10
Fourth one down is a PDF.
Old Jul 29, 2014 | 09:52 PM
  #39
WESIDE's Avatar
WESIDE
A link would be great. I cant seem to find it.
Old Jul 29, 2014 | 11:03 PM
  #40
tadst34's Avatar
tadst34
http://www.sequentialtaillights.com/dodge/SB_PDF/TSB_LC_0801010.pdf
