Old Aug 5, 2015, 08:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
key fob problems
Old Mar 22, 2011 | 08:08 PM
zx14k's Avatar
zx14k
Default key fob problems
HI. truck is 09 hemi with remote start,key fob never work so well but this morning nothing cant unlock the doors cant start........try the 2 key fob nothing,i have to take the small key to open the door and start the truck with the key.drive arond 5 miles and try again and all is working fine.anyone have this problem before.thank
Old Mar 22, 2011 | 08:59 PM
WNDERR's Avatar
WNDERR
Needs a new battery?????
Old Mar 22, 2011 | 09:08 PM
zx14k's Avatar
zx14k
battery are new on both key fob
Old Mar 22, 2011 | 09:23 PM
alhemi09's Avatar
alhemi09
Hi zx14k just take your remote and remove the battery you will see four small pins just bend them for a better contact with the battery and your problem should be fixed.
Old Mar 22, 2011 | 09:24 PM
BigTexMarine's Avatar
BigTexMarine
I actually had this problem about a year ago. It was something in the key fob that was keeping it from transmitting to the truck, I took it in to the dealership and they swapped my key fob and it worked fine after that.
Old Mar 22, 2011 | 10:29 PM
dizzyttc's Avatar
dizzyttc
Had this problem with my remotes not always opening doors. Took them to the dealer a few weeks ago and they replaced both of my remotes with new ones and programmed them for me. Dealer told me Chrysler knows of the problem and that's why Chrysler changed manufacture for the remote.
Old Mar 23, 2011 | 11:17 AM
jawsdc's Avatar
jawsdc
hey dizzy,
you wouln't still have a copy of your service receipt would you?
it would certainly be helpful to have a copy of yours. my dealer knows nothing of the key fob replacement option.
thanks
Old Mar 23, 2011 | 05:08 PM
72combo's Avatar
72combo
Move on to a different dealer, it is called warranty and if they don't understand that then you are in trouble.
Old Mar 23, 2011 | 07:05 PM
merv's Avatar
merv
I had my fob not work when trying to unlock and remote start. Icleaned the contacts with a qtip and alcohol, slightly bent out the 4 prongs that touch the battery, AND the two prongs on the side.
It has worked great since I did that; 2 weeks and counting.
Old Mar 24, 2011 | 01:31 AM
dizzyttc's Avatar
dizzyttc
When I get a chance I,ll see if the dealer put any codes for replacing the remotes on the work order. This was done at my dealer in Toronto.
